– I found that my Macbook was no longer able to see the Time Machine share so I logged into the web ui and found this error.
– login to the web ui
File "/opt/rockstor/src/rockstor/storageadmin/views/appliances.py", line 41, in get_queryset
self._update_hostname()
return func(*args, **kwargs)
File "/opt/rockstor/src/rockstor/storageadmin/views/appliances.py", line 48, in _update_hostname
cur_hostname = gethostname()
File "/opt/rockstor/src/rockstor/system/osi.py", line 760, in gethostname
o, e, rc = run_command([HOSTNAMECTL, '--static'])
File "/opt/rockstor/src/rockstor/system/osi.py", line 107, in run_command
raise Exception(msg)
Exception: Exception while running command(['/usr/bin/hostnamectl', '--static']): [Errno 24] Too many open files
