getting error on rescanning disks ‘expected string or buffer’
Rockstor: 3.8.16-1
My main rockstor system died. I’m trying to import the data disks into a new rockstor system. When I click on the rescan button to get a list of disks I get this error.
If I do an fdisk -l or btrfs fi show, I see all the data disks and data pools.
Although the GUI gives an error, rockstor actually mounts the data pools into /mnt2 and I can access the data via the CLI, but the GUI does not list the drives - pools - or shares. Has anyone see this before? have tips on a workaround? Thanks!
File "/opt/rockstor/src/rockstor/storageadmin/views/disk.py", line 272, in post
return func(*args, **kwargs)
File "/opt/rockstor/src/rockstor/storageadmin/views/disk.py", line 238, in _update_disk_state
if (re.match('fake-serial-', do.serial) is not None) or \
File "/usr/lib64/python2.7/re.py", line 137, in match
return _compile(pattern, flags).match(string)
