When to use the wipe disk
Clicked disks
Clicked on the first disk (little eraser icon)
Select Partition to use (filesystem) * Whole disk btrfs
ticked wipe data
Clicked submit and blam error as you see below.
File “/opt/rockstor/src/rockstor/storageadmin/views/disk.py”, line 921, in _role_disk
return self._wipe(disk.id, request)
return func(*args, **kwargs)
File “/opt/rockstor/src/rockstor/storageadmin/views/disk.py”, line 616, in _wipe
wipe_disk(disk_name)
File “/opt/rockstor/src/rockstor/system/osi.py”, line 864, in wipe_disk
return run_command([WIPEFS, ‘-a’, disk_byid_withpath])
File “/opt/rockstor/src/rockstor/system/osi.py”, line 120, in run_command
CommandException: Error running a command. cmd = /usr/sbin/wipefs -a /dev/disk/by-id/wwn-0x600508b1001c389ff5bd27d507d77cb7. rc = 1. stdout = [‘’]. stderr = [‘wipefs: error: /dev/disk/by-id/wwn-0x600508b1001c389ff5bd27d507d77cb7: probing initialization failed: Device or resource busy’, ‘’]
