Disks are not mounting into the pool after rebooting the system.
- Reboot the machine
- Logs showing the same error as when attempt to re-add the disks (see below)
File "/opt/rockstor/src/rockstor/storageadmin/views/pool.py", line 632, in put
self._resize_pool_start(pool, dnames)
File "/opt/rockstor/src/rockstor/storageadmin/views/pool.py", line 347, in _resize_pool_start
cmd = resize_pool_cmd(pool, dnames, add)
File "/opt/rockstor/src/rockstor/fs/btrfs.py", line 687, in resize_pool_cmd
root_mnt_pt = mount_root(pool)
File "/opt/rockstor/src/rockstor/fs/btrfs.py", line 795, in mount_root
"Command used {}".format(pool.name, mnt_cmd)
Exception: Failed to mount Pool(Hughes) due to an unknown reason. Command used ['/usr/bin/mount', '/dev/disk/by-label/Hughes', '/mnt2/Hughes']
