Cannot start samba
File "/opt/rockstor/src/rockstor/smart_manager/views/samba_service.py", line 114, in post
systemctl('smb', command)
File "/opt/rockstor/src/rockstor/system/services.py", line 64, in systemctl
CommandException: Error running a command. cmd = /usr/bin/systemctl start smb. rc = 1. stdout = ['']. stderr = ['Job for smb.service failed because the control process exited with error code. See "systemctl status smb.service" and "journalctl -xe" for details.', '']
Nov 13 13:12:16 nas systemd[1]: Starting Samba SMB Daemonβ¦
Nov 13 13:12:16 nas systemd[1]: smb.service: Supervising process 10558 which is not our child. Weβll most likely not notice when it exits.
Nov 13 13:12:16 nas smbd[10558]: [2018/11/13 13:12:16.824114, 0] β¦/source3/auth/auth_util.c:1399(make_new_session_info_guest)
Nov 13 13:12:16 nas smbd[10558]: create_local_token failed: NT_STATUS_NO_MEMORY
Nov 13 13:12:16 nas smbd[10558]: [2018/11/13 13:12:16.824183, 0] β¦/source3/smbd/server.c:2011(main)
Nov 13 13:12:16 nas smbd[10558]: ERROR: failed to setup guest info.
Nov 13 13:12:16 nas systemd[1]: smb.service: main process exited, code=exited, status=255/n/a
Nov 13 13:12:16 nas systemd[1]: Failed to start Samba SMB Daemon.
Nov 13 13:12:16 nas systemd[1]: Unit smb.service entered failed state.
Nov 13 13:12:16 nas systemd[1]: smb.service failed.
β A new session with the ID 8 has been created for the user root.
β The leading process of the session is 4370.
Nov 13 16:41:07 nas systemd[1]: Starting Session 8 of user root.
β Subject: Unit session-8.scope has begun start-up
β Defined-By: systemd
β Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
β Unit session-8.scope has begun starting up.
Nov 13 16:41:07 nas sshd[4370]: pam_unix(sshd:session): session opened for user root by (uid=0)
Nov 13 16:41:09 nas kernel: wbinfo[4516]: segfault at 0 ip 00007f4371b3a67f sp 00007ffd08f6c7b8 error 4 in libc-2.17.so[7f4
Nov 13 16:41:25 nas kernel: wbinfo[4581]: segfault at 0 ip 00007f7a8dd7c67f sp 00007ffc263d5548 error 4 in libc-2.17.so[7f7
Nov 13 16:41:41 nas kernel: wbinfo[4602]: segfault at 0 ip 00007f748532c67f sp 00007ffd166b4a58 error 4 in libc-2.17.so[7f7
Nov 13 16:41:47 nas sudo[4603]: root : TTY=pts/0 ; PWD=/root ; USER=root ; COMMAND=/bin/systemctl status smb.service
Nov 13 16:41:56 nas kernel: wbinfo[4626]: segfault at 0 ip 00007fcd3f9b967f sp 00007ffd51567228 error 4 in libc-2.17.so[7fc
Nov 13 16:42:12 nas kernel: wbinfo[4648]: segfault at 0 ip 00007f8ab5f0067f sp 00007fff6a37eda8 error 4 in libc-2.17.so[7f8
Nov 13 16:42:22 nas sudo[4661]: root : TTY=pts/0 ; PWD=/root ; USER=root ; COMMAND=/bin/systemctl status smb.service -l
Nov 13 16:42:28 nas kernel: wbinfo[4716]: segfault at 0 ip 00007f39d97d967f sp 00007ffc8d821c38 error 4 in libc-2.17.so[7f3
Nov 13 16:42:43 nas kernel: wbinfo[4741]: segfault at 0 ip 00007f7737fa467f sp 00007ffdb630f898 error 4 in libc-2.17.so[7f7
Nov 13 16:42:59 nas kernel: wbinfo[4763]: segfault at 0 ip 00007fbaec48d67f sp 00007fff0e5b7378 error 4 in libc-2.17.so[7fb
Nov 13 16:43:15 nas kernel: wbinfo[4784]: segfault at 0 ip 00007f2ca4ba567f sp 00007ffe2a9b0098 error 4 in libc-2.17.so[7f2
Nov 13 16:43:31 nas kernel: wbinfo[4851]: segfault at 0 ip 00007fac0ae5c67f sp 00007fffa5a9a928 error 4 in libc-2.17.so[7fa
Nov 13 16:43:37 nas sudo[4852]: root : TTY=pts/0 ; PWD=/root ; USER=root ; COMMAND=/bin/journalctl -xe
lines 1313-1347/1347 (END)
β Unit session-8.scope has finished starting up.
