I have a drive that failed in a 4 disk RAID10 pool. I have been following the Data Lossa Raid 1 documentation without any luck. The drive is completely dead so it doesn’t register as a device anymore. I mount the pool and run the replace:
btrfs replace start 1 /dev/sdf /mnt2/raider10
But when i look at the status it says ‘Never started’. It won’t let me mount the pool as RW, an error is thrown
fdisk -l
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes, 1953525168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk label type: dos
Disk identifier: 0x00017bcd
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 1026047 512000 83 Linux
/dev/sda2 1026048 5222399 2098176 82 Linux swap / Solaris
/dev/sda3 5222400 1953523711 974150656 83 Linux
Disk /dev/sdb: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/sdc: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Disk /dev/sdd: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Disk /dev/sde: 1000.2 GB, 1000204886016 bytes, 1953525168 sectors
Disk /dev/sdf: 3000.6 GB, 3000592982016 bytes, 5860533168 sectors
btrfs fi show
Label: 'rockstor_rockstor' uuid: 9a41126b-4153-42d4-b106-ff205d2f260e
Total devices 1 FS bytes used 2.47GiB
devid 1 size 929.02GiB used 5.04GiB path /dev/sda3
Label: 'raider10' uuid: 182033a2-cad6-4a4f-aece-1a8ddf038736
Total devices 4 FS bytes used 407.76GiB
devid 2 size 1.82TiB used 206.04GiB path /dev/sdc
devid 3 size 1.82TiB used 207.01GiB path /dev/sdd
devid 4 size 1.82TiB used 207.01GiB path /dev/sdb
*** Some devices missing
