It appears that Rockstor uses a customized supervisord python base script (/opt/rockstor/bin/supervisord)
In playing around with running up a new docker container for a (hopefully!) up-and-coming new Rockon, I appear to have broken this by manually installing supervisor from yum.
At a guess, I’ve overwritten certain python libs with newer versions incompatible with Rockstor’s changes?
I’m currently looking at symlinking the new supervisord start script to /opt/rockstor/bin/supervisord, as well as supervisorctl, however I’m not sure what I’ll be breaking in this process.
I’ve managed to get the Rockstor UI started by altering the Rockstor systemd unit to use /usr/bin/supervisord, however errors crop up elsewhere.
Currently, I’m receiving errors when attempting to install any Rockons, however I assume that this will be true for anything that Rockstor attempts to use supervisorctl for.
The error I receive is as follows:
File "/opt/rockstor/src/rockstor/storageadmin/views/rockon_id.py", line 84, in post
if (rc == 1):
UnboundLocalError: local variable 'rc' referenced before assignment
Alternatively, I could force a re-install of the Rockstor package, if you think it’ll help. However, will this blow away any of my existing settings from Rockstor’s POV? (Pools, shares, services, Custom Rockon JSON, etc)
