Getting the error below everywhere I go, mostly with the actual UI below it, except for the pool properties which aren’t loading at all.
Started after a scrub, reproducable on my system on essentially every page of the web UI
File "/opt/rockstor/src/rockstor/storageadmin/views/pool_scrub.py", line 46, in get_queryset
self._scrub_status(pool)
return func(*args, **kwargs)
File "/opt/rockstor/src/rockstor/storageadmin/views/pool_scrub.py", line 65, in _scrub_status
PoolScrub.objects.filter(id=ps.id).update(**cur_status)
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/query.py", line 563, in update
rows = query.get_compiler(self.db).execute_sql(CURSOR)
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/compiler.py", line 1062, in execute_sql
cursor = super(SQLUpdateCompiler, self).execute_sql(result_type)
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/compiler.py", line 840, in execute_sql
cursor.execute(sql, params)
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/backends/utils.py", line 64, in execute
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/utils.py", line 98, in __exit__
DataError: integer out of range
I just went down a rabbithole …
