S.M.A.R.T error on newly added disk drive
I added a new drive and reboot. The new drive gets /dev/sda (something else was sda before), possibly due to shuffling of the sata cables.
The Refresh the smart details gave the errors as shown in stack trace below
File "/opt/rockstor/src/rockstor/storageadmin/views/disk_smart.py", line 116, in post
return self._info(disk)
return func(*args, **kwargs)
File "/opt/rockstor/src/rockstor/storageadmin/views/disk_smart.py", line 74, in _info
sa.save()
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/base.py", line 734, in save
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/base.py", line 762, in save_base
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/base.py", line 846, in _save_table
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/base.py", line 885, in _do_insert
using=using, raw=raw)
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/query.py", line 920, in _insert
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/compiler.py", line 973, in execute_sql
for sql, params in self.as_sql():
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/compiler.py", line 931, in as_sql
for obj in self.query.objs
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/fields/__init__.py", line 710, in get_db_prep_save
prepared=False)
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/fields/__init__.py", line 702, in get_db_prep_value
value = self.get_prep_value(value)
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/fields/__init__.py", line 1869, in get_prep_value
return int(value)
ValueError: invalid literal for int() with base 10: '---'
@amtuannguyen Welcome to the Rockstor community and thanks for your report.
Given that this issue is most likely caused by a peculiarity in the output of your drive’s S.M.A.R.T data is it necessary to gain the same output so that someone can have a go at sorting what’s causing this. As it goes there is included in Rockstor a shell script to grab and zip up the same outputs from smartctl as are used internally and we have a flag that means we can test submitted output.:
sh /opt/rockstor-dev/src/rockstor/scripts/dump-smart.sh
Please supply a single device name using the /dev/sdX or /dev/disk/by-id reference
N.B. Use the base device - not a partition reference.
eg /opt/rockstor-dev/src/rockstor/scripts/dump-smart.sh /dev/disk/by-id/ata-ST3160021AS_5JS1HNX9
So if you could execute that same program only substituting your newly added and smart parsing problem drive name instead of the example “ata-ST3160021AS_5JS1HNX9” drive name given (TAB key for auto complete may help) then you should end up with a file in your /root directory:
/root/smart-issue-report.tar.gz
if you could attach that file to this forum thread then someone can take a look at the problem, although it may take some time of course.
Please note that the serial number of your drive will be included in this output, just so you know.
Let us know if there is a problem with this procedure and we can take it from there. I know previously we were unable to attach such files but I think this has now been sorted in the forum config.
@amtuannguyen Thanks for submitting the smart data. I had a quick look earlier and was able to reproduce the error here using your SMART data. It seems the issue is that your drive model is reporting “—” for every attribute threshold which is not something that has been reported or seen before. Anyway I’ve opened an issue for it:
And have submitted a fix / work around by way of a pull request against that issue:
If you are in a rush, or curios, you could make the changes indicated in that pull request to your own copy:
/opt/rockstor/src/rockstor/system/smart.py
otherwise you can just wait to see if those changes pass review and get merged. Nano is pre-installed and easy to use. No need to add the lines beginning with ‘#’ as they are just comments and if you do go the route of self patching then be very careful to make only these changes exactly as they are in that pr: including exact indentation. Probably best to take a copy of the file first, just in case, but don’t leave it in the Rockstor src tree; ie put it in /root as a backup for example.
Thanks again for reporting this. So at least our SMART parsing shouldn’t fall over in that way again, assuming it get merged that is.
Note that if you do make those changes by hand you will need to restart the rockstor service, or just reboot, for the changes to take effect.
Hope that helps and thanks again for assisting with this fix.
@amtuannguyen Your welcome and thanks for the fix / work around confirmation. Bit odd that there are no threshold values. It may be that this changes in the future but at least we catch the situation for now.
