Docker is no longer listed when doing docker ps
Shares deleted
updated from 5.0.11 to 5.0.13
Rebooted
Not sure what else to try
Other rockons will install and uninstall while this is happening.
We’ve seen this kind of odd behavior a few times. Unfortunately it’s not easy to really know the cause as it always seems difficult to reproduce.
Nevertheless, we have a script that will force uninstall a Rock-on stuck like that. Have a look at the documentation at the link below: https://rockstor.com/docs/interface/overview.html#force-uninstall-of-a-rock-on
Let us know if that helps or if you’d like more details on how to run it; we’ll be happy to help as needed!
Thanks @Flox for the help that worked
I should have looked in rockstor documentation instead of docker
New to linux and rockstor, was just looking for a resolution for my issue I understand a issue like this is hard to reproduce and doesn’t cause any actual error aside from the web UI.
No worries; you had the right approach.
We do have plans to integrate thai force uninstall in Rockstor’s Web UI in the future to make it easier and simpler. No timeline for it yet, unfortunately.
Glad it helps, and let us know how it goes! Don’t hesitate to ask here any other question(s) you may have.
