Hi @Hooverdan,
thanks for answering so fast.
System information:
- Rockstor 4.1.0-0
- Linux NAS 5.3.18-150300.59.54-default #1 SMP Sat Mar 5 10:00:50 UTC 2022 (1d0fa95) x86_64 x86_64 x86_64 GNU/Linux
Motherboard: Asrock J3455
lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
Address sizes: 39 bits physical, 48 bits virtual
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 92
Model name: Intel® Celeron® CPU J3455 @ 1.50GHz
Stepping: 9
CPU MHz: 2288.009
CPU max MHz: 2300,0000
CPU min MHz: 800,0000
BogoMIPS: 2995.20
Virtualization: VT-x
L1d cache: 96 KiB
L1i cache: 128 KiB
L2 cache: 2 MiB
NUMA node0 CPU(s): 0-3
Vulnerability Itlb multihit: Not affected
Vulnerability L1tf: Not affected
Vulnerability Mds: Not affected
Vulnerability Meltdown: Not affected
Vulnerability Spec store bypass: Vulnerable
Vulnerability Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Vulnerability Spectre v2: Mitigation; Retpolines, IBPB conditional, IBRS_FW, STIBP disabled, RSB filling
Vulnerability Srbds: Not affected
Vulnerability Tsx async abort: Not affected
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse
sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xt
opology tsc_reliable nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl v
mx est tm2 ssse3 sdbg cx16 xtpr pdcm sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave rd
rand lahf_lm 3dnowprefetch cpuid_fault cat_l2 ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ep
t_ad fsgsbase tsc_adjust smep erms mpx rdt_a rdseed smap clflushopt intel_pt sha_ni xsaveopt xsavec xg
etbv1 xsaves dtherm ida arat pln pts arch_capabilities
The only thing I have modified in the system are two systemd services:
- I added this service as it said here for WOL to work:
NAS:/etc/systemd/system # cat WOL-eth0.service
[Unit]
Description=Wake-on-LAN for eth0
Requires=network.target
After=network.target
[Service]
ExecStart=/usr/sbin/ethtool -s eth0 wol g
Type=oneshot
[Install]
WantedBy=multi-user.target
- I added the option of TimeoutStopSec=480 on docker.service because it had rock-ons that with corrupted data when shutting down the system. I already had this configuration in my previous NAS operating system. These problems occurred mainly with jellyfin
NAS:/etc/systemd/system # cat docker.service
[Unit]
Description=Docker Application Container Engine
Documentation=http://docs.docker.com
After=network.target lvm2-monitor.service SuSEfirewall2.service rockstor-bootstrap.service
[Service]
EnvironmentFile=/etc/sysconfig/docker
# While Docker has support for socket activation (-H fd://), this is not
# enabled by default because enabling socket activation means that on boot your
# containers won’t start until someone tries to administer the Docker daemon.
Type=notify
NotifyAccess=all
ExecStart=/usr/bin/dockerd --add-runtime oci=/usr/sbin/docker-runc $DOCKER_NETWORK_OPTIONS $DOCKER_OPTS --config-file /opt/rockstor/conf/docker-daemon.json
ExecReload=/bin/kill -s HUP $MAINPID
TimeoutStopSec=480
# Having non-zero Limit*s causes performance problems due to accounting overhead
# in the kernel. We recommend using cgroups to do container-local accounting.
LimitNOFILE=1048576
LimitNPROC=infinity
LimitCORE=infinity
# Uncomment TasksMax if your systemd version supports it.
# Only systemd 226 and above support this property.
TasksMax=infinity
# Set delegate yes so that systemd does not reset the cgroups of docker containers
# Only systemd 218 and above support this property.
Delegate=yes
# Kill only the docker process, not all processes in the cgroup.
KillMode=process
# Restart the docker process if it exits prematurely.
Restart=on-failure
StartLimitBurst=3
StartLimitInterval=60s
[Install]
Thanks so much for your help
