Problem after upgrade from 3.9.1-1 to 3.9.1-7 (relation "storageadmin_pincard" does)
After update to the new Version 3.9.9.1-7 i got this error when i’am trying to access a share via <Shares → [Share]>
goto Storage/Shares and click on a Share-Name
File “/opt/rockstor/src/rockstor/storageadmin/views/user.py”, line 113, in get_queryset
return combined_users()
File “/opt/rockstor/src/rockstor/storageadmin/views/ug_helpers.py”, line 69, in combined_users
temp_uo.pincard_allowed, temp_uo.has_pincard = pincard_states(temp_uo) # noqa E501
File “/opt/rockstor/src/rockstor/system/pinmanager.py”, line 146, in pincard_states
pincard_present = has_pincard(user)
File “/opt/rockstor/src/rockstor/system/pinmanager.py”, line 129, in has_pincard
pins = Pincard.objects.filter(user=int(uid_field)).count()
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/query.py”, line 318, in count
return self.query.get_count(using=self.db)
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/query.py”, line 466, in get_count
number = obj.get_aggregation(using, [‘__count’])[‘__count’]
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/query.py”, line 447, in get_aggregation
result = compiler.execute_sql(SINGLE)
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/compiler.py”, line 840, in execute_sql
cursor.execute(sql, params)
ProgrammingError: relation “storageadmin_pincard” does not exist
LINE 1: SELECT COUNT(*) AS “__count” FROM “storageadmin_pincard” WHE…
@Manfred_Wilhelm Welcome to the Rockstor community.
Your report is a little confusing as it points to a failed db migration when non have happened between 3.9.1-1 to 3.9.1-7. Could it be that you mean an upgrade from some version less than 3.8-14.3 to 3.9.1-7 (see later for details). You might find that a reboot will sort this however. If you paste the output of the following command run as root it should indicate what has been applied db migration wise (this will only work on more recent version of Rockstor):
/opt/rockstor/bin/django showmigrations
You may well find that a reboot will sort this as the db migration may sort itself out.
relates to the following addition:
If you have in fact upgraded from such an old version (ie < 3.8.15) then if you find that a reboot does not sort your install out then you may want to take a look at the following post as in the mean time we have changed our database migration system; essentially if you were not running a stable subscritpion with auto update enabled you may have to have stopped off at 3.8.15 first.
The part that may apply to you is the heading:
“I have a broken system after upgrading to 3.8.16. What do I do?”
Obviously as that post is now quite old it would be better, if you are to take the alternative re-install route describe there, to use the latest iso which as of this post is 3.9.1.iso.
