Unfortunately raid1c3 etc are not yet implemented in the Rockstor GUI. Thatās not to say the CLI might not be an option, but I could not say how that would be reflected in the web interface - and its not something i have tried.
I think the 3 and 4 copy versions of btrfs raid1 would be a nice inclusion at some point, but there is so much underway with the tantalisingly close release of v4, and limited resources to do everything, that this may be later rather than sooner.
If youāre just itching to try (I was) you can update your kernel and btrfs-progs on your own following the info in this post: Upgrade Kernel to 4.16
Specifically:
Just DO NOT remove btrfs-progs, it causes issues, just leave it be.
Then you can convert your metadata to raid1c3 - I donāt have the exact command off-hand, but itās something like:
btrfs balance start -mconvert=raid1c3 /YOUR-MOUNT
Iāve successfully updated to kernel and btrfs-progs 5.11 with this method and have my own raid5 volume metadata at raid1c3
**NOTE: You will not be able to directly import these shares into the Rockstor4 environment until it defaults to a newer kernel and btrfs-progs OR you update on your own manually.
And as of writing those installers are build from our kiwi-ng config here:
No unfortunately not. Although if you donāt do Web-UI initiated balances or disk manipulations then it may just leave things well-alone and report itās slightly confused interpretation. But note that these levels are the earliest additions to to btrfs and have had very little field testing even in comparison the the parity raids that are still known to be flaky. But at least they are based on better āgroundsā than the partiy 5/6 levels. I think you will also need to use a newer kernel for these levels as I donāt think openSUSE SuSE have back-ported these raid levels to Leap 15.3 or SLES 15 sp3 yet so that may be a warning of sorts also.
So take a look also at @kageurufu excellent recent post on their journey with doing the same, along with btrfs-progs, as they also are using RAID1C4 with our āBuilt on openSUSEā v4.
But keep in mind such things as are indicated in the following issue we have open on upstream kernel changes. Itās not just additions but also subtractrions/alterations that have to be accounted for when making such core changes to an os:
