Hi. I’m on Rockstor 3.9.2-22
My server’s motherboard (ASRock C2550D4I) died recently. I had it RMA. After I installed the new motherboard, I wanted to turn off the network bonding feature. When I used the UI to turn on one of the dual NIC, I got the following error message:
Houston, we’ve had a problem.
Error running a command. cmd = /usr/bin/nmcli c up 803043f3-e4e2-4fc0-b409-45c13359b66a. rc = 4. stdout = [’’]. stderr = [‘Error: Connection activation failed: No suitable device found for this connection.’, ‘’]
File “/opt/rockstor/src/rockstor/storageadmin/views/network.py”, line 380, in post
network.toggle_connection(nco.uuid, switch)
File “/opt/rockstor/src/rockstor/system/network.py”, line 198, in toggle_connection
return run_command([NMCLI, ‘c’, switch, uuid])
CommandException: Error running a command. cmd = /usr/bin/nmcli c up 803043f3-e4e2-4fc0-b409-45c13359b66a. rc = 4. stdout = [’’]. stderr = [‘Error: Connection activation failed: No suitable device found for this connection.’, ‘’]
I know my ways around Linux. Can you please tell me how to clear the RockStor configuration database and remove the network bonding?
Thanks
