Just updated and from performing the updated here are the issues I ran into
This is list of the item in case anyone else experiences these
Installation menu is defaulted to Install Rockstor, when this is used the system does not install rockstor with dtrfs file system for home or root
Install system using the test media and install menu option and system installed just fine
During the install process any time a window is presented with the quit button it takes completely out of the install, this is very annoying and should be resolved. Depending on the windows and situation at a minimum it should return to the previous window.
After the install I am now missing my network widget data I have the drop down box for them and can select each one but I get no graphs or charts, this was working in 3.8.12 and below for my hardware.
All other widgets are working as before
Attempted to turn on rock-ons and am getting some issues with being able to get out to the rock-on metastore Still working on this as it seems to be related to network configuration of the docker network connection.
Hope this helps anyone who may be installed 3.8.13
