Rock-ons are a Docker wrapper. Regarding the referenced docker image:
filebrowser/filebrowser
The current full list of available Rock-ons are as per the Rockstor Web-UI display which is currently the same as those available in our Rock-on GitHub repository:
Our docs are often behind the full list.
Also note that the above rockon-registry has instructions on writing/submitting your own Rock-ons.
@ZeusMR if you choose to accept the challenge on submitting a Rockon for fileserver, I would recommend to focus on the version (tag) that uses linuxserverās s6 overlay instead of the alpine version:
That will then allow you (in typical linuxserver.io fashion) to specify a User and Group ID that then also should allow to contain the container to managing files/directories that you want (as opposed to root, unless thatās what you are looking for).
If youāre looking for a quick option to manage/copy/move files without using the command line (or doing it, say, from Windows Explorer on a connected machine), then you could install something like Midnight Commander and access it through the Rockstor Shell in the WebUI. Some time ago, there was a discussion around that:
Obviously comes with pros and cons as well, and depends on what your use case is.
Well, I somehow had some time on my hands. I created an issue and a Pull Request for filebrowser on github just now:
I successfully installed it on my test machine ⦠tricky part is to ensure the initial database file has the correct permissions, but other than that, no issue running it.
So, whenever this one goes through another review cycle it might become available. If you canāt wait that long you can check out the json submitted and roll your own.
Finnally got to this and Iāve detailed some issues in the PR review but published what we have to date. We can always revisit, and Iām not keen on the fiddly need to create the initial empy db file !
