Hello @Flox. Here’s the outputs, hope it helps:
systemctl status nmb.service
[root@pauloserver ~]# systemctl status nmb.service
● nmb.service - Samba NMB Daemon
Loaded: loaded (/usr/lib/systemd/system/nmb.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2020-05-29 06:31:22 PDT; 4min 57s ago
Docs: man:nmbd(8)
man:samba(7)
man:smb.conf(5)
Main PID: 2202 (nmbd)
Status: “nmbd: ready to serve connections…”
CGroup: /system.slice/nmb.service
└─2202 /usr/sbin/nmbd --foreground --no-process-group
May 29 06:31:22 pauloserver systemd[1]: Starting Samba NMB Daemon…
May 29 06:31:22 pauloserver systemd[1]: Started Samba NMB Daemon.
May 29 06:31:22 pauloserver nmbd[2202]: [2020/05/29 06:31:22.989561, 0] …/…/lib/util/become_daemon.c:136(daemon_ready)
May 29 06:31:22 pauloserver nmbd[2202]: daemon_ready: daemon ‘nmbd’ finished starting up and ready to serve connections
May 29 06:31:50 pauloserver nmbd[2202]: [2020/05/29 06:31:50.337715, 0] …/…/source3/nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
May 29 06:31:50 pauloserver nmbd[2202]: *****
May 29 06:31:50 pauloserver nmbd[2202]: Samba name server PAULOSERVER is now a local master browser for workgroup SAMBA on subnet 192.168.8.110
journalctl -u nmb.service
[root@pauloserver ~]# journalctl -u nmb.service
– Logs begin at Fri 2020-05-29 06:31:13 PDT, end at Fri 2020-05-29 06:35:45 PDT. –
systemctl status smb.service
[root@pauloserver ~]# systemctl status smb.service
● smb.service - Samba SMB Daemon
Loaded: loaded (/etc/systemd/system/smb.service; enabled; vendor preset: disabled)
Active: failed (Result: protocol) since Fri 2020-05-29 06:35:45 PDT; 1min 25s ago
Process: 3197 ExecStart=/usr/sbin/smbd $SMBDOPTIONS (code=exited, status=0/SUCCESS)
Main PID: 3197 (code=exited, status=0/SUCCESS)
May 29 06:35:45 pauloserver systemd[1]: Starting Samba SMB Daemon...
May 29 06:35:45 pauloserver systemd[1]: Failed to start Samba SMB Daemon.
May 29 06:35:45 pauloserver systemd[1]: Unit smb.service entered failed state.
May 29 06:35:45 pauloserver systemd[1]: smb.service failed.
journalctl -u smb.service
[root@pauloserver ~]# journalctl -u smb.service
May 29 06:32:00 pauloserver systemd[1]: Starting Samba SMB Daemon…
May 29 06:32:00 pauloserver systemd[1]: Failed to start Samba SMB Daemon.
May 29 06:32:00 pauloserver systemd[1]: Unit smb.service entered failed state.
May 29 06:32:00 pauloserver systemd[1]: smb.service failed.
May 29 06:34:44 pauloserver systemd[1]: Starting Samba SMB Daemon…
May 29 06:34:44 pauloserver systemd[1]: Failed to start Samba SMB Daemon.
May 29 06:34:44 pauloserver systemd[1]: Unit smb.service entered failed state.
May 29 06:34:44 pauloserver systemd[1]: smb.service failed.
May 29 06:35:45 pauloserver systemd[1]: Starting Samba SMB Daemon…
Here's the error the UI gives when i try to turn on the Samba Service:
Failed to start samba due to a system error: Error running a command. cmd = /usr/bin/systemctl start smb. rc = 1. stdout = [‘’]. stderr = [‘Job for smb.service failed. See “systemctl status smb.service” and “journalctl -xe” for details.’, ‘’]
File “/opt/rockstor/src/rockstor/smart_manager/views/samba_service.py”, line 114, in post
systemctl(‘smb’, command)
File “/opt/rockstor/src/rockstor/system/services.py”, line 64, in systemctl
CommandException: Error running a command. cmd = /usr/bin/systemctl start smb. rc = 1. stdout = [‘’]. stderr = [‘Job for smb.service failed. See “systemctl status smb.service” and “journalctl -xe” for details.’, ‘’]
Trying to configure Samba in the wrench tool throws the same error as above. The toggle reverts itself back off after a few seconds.
Thank you for trying to help!
