Samba service is not starting
after I uninstalled vbox 5.1 and installed vbox 5.2 my samba service is unable to start.
When I try to start the service I get a message:
" Failed to start samba due to a system error: Error running a command. cmd = /usr/bin/systemctl start nmb. rc = 1. stdout = [’’]. stderr = [‘Job for nmb.service failed because the control process exited with error code. See “systemctl status nmb.service” and “journalctl -xe” for details.’, ‘’] "
" Traceback (most recent call last):
File “/opt/rockstor/src/rockstor/smart_manager/views/samba_service.py”, line 113, in post
systemctl(‘nmb’, command)
File “/opt/rockstor/src/rockstor/system/services.py”, line 64, in systemctl
CommandException: Error running a command. cmd = /usr/bin/systemctl start nmb. rc = 1. stdout = [’’]. stderr = [‘Job for nmb.service failed because the control process exited with error code. See “systemctl status nmb.service” and “journalctl -xe” for details.’, ‘’] "
" journalctl -xe " gives no real information why the samba service was stopped
Status of systemctl gives some hint, but I don’t know how to solve the issue…
" systemctl status nmb.service
● nmb.service - Samba NMB Daemon
Loaded: loaded (/usr/lib/systemd/system/nmb.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Sat 2018-07-28 11:16:14 PDT; 15min ago
Process: 31846 ExecStart=/usr/sbin/nmbd --foreground --no-process-group $NMBDOPTIONS (code=exited, status=1/FAILURE)
Main PID: 31846 (code=exited, status=1/FAILURE)
Jul 28 11:16:14 rock-srv systemd[1]: Starting Samba NMB Daemon…
Jul 28 11:16:14 rock-srv nmbd[31846]: /usr/sbin/nmbd: /usr/lib64/samba/libreplace-samba4.so: version SAMBA_4.6.2' not found (required by /lib64/libwbclient.so.0)** **Jul 28 11:16:14 rock-srv nmbd[31846]: /usr/sbin/nmbd: /usr/lib64/samba/libwinbind-client-samba4.so: versionSAMBA_4.6.2’ not found (required by /lib64/libwbclient.so.0)
Jul 28 11:16:14 rock-srv systemd[1]: nmb.service: main process exited, code=exited, status=1/FAILURE
Jul 28 11:16:14 rock-srv systemd[1]: Failed to start Samba NMB Daemon.
Jul 28 11:16:14 rock-srv systemd[1]: Unit nmb.service entered failed state.
Jul 28 11:16:14 rock-srv systemd[1]: nmb.service failed. "
I hope some of you could help me…
Thanks.
KR
Chavell3
Hi @Chavell3,
Have you tried applying the latest Rockstor update, and then applying all the package updates that are available?
I had the same problem, and applying the latest Rockstor update at the time, and then updating my packages after is what fixed it.
Hope this helps!
systemclt restart smb nmb
systemctl enable smb nmb
systemctl status
thanks guys.
But unfortunatly both are not helping.
I looked for updates but I’m currently running on the latest release 3.9.2-31.
I also tried the systemctl commands, but also no success…
I get a message:
" Job for smb.service failed because the control process exited with error code. See “systemctl status smb.service” and “journalctl -xe” for details. "
:frowning:
@Chavell3 I’ll just chip in here.
Can you confirm this via:
yum info rockstor
just to make sure you are not affected by a false version report bug when updating from testing to stable.
yum update rockstor
Should resolve this if you find your installed version is not actually 3.9.2-31
Also take a look at the following forum thread that may be relevant to your issue which occurred around 3.9.1-11:
of particular note are @Haioken’s posts in that thread.
Hope that helps, and remember the ‘update all but Rockstor package’ flashing wifi symbol by “Linux” kernel version in top right of Web-UI.
thanks Philip,
yum info rockstor delivers :
" [root@rock-srv ~]# yum info rockstor
Installed Packages
Arch : x86_64
Version : 3.9.2
Release : 5
Repo : installed
From repo : Rockstor-Stable
Summary : RockStor – Store Smartly
License : GPL
Description : RockStor – Store Smartly
Available Packages
Arch : x86_64
Version : 3.9.2
Release : 31
Repo : Rockstor-Stable
License : GPL
Description : RockStor – Store Smartly "
so it seemed -31 was not installed… I installed it now:
" Installed Packages
Arch : x86_64
Version : 3.9.2
Release : 31
Repo : installed
License : GPL
but samba service is still not startable.
I will have a look at your suggested thread.
Thanks.
@Chavell3 By the way, we missed the customary 'Welcome to the Rockstor community"
Yes it’s not related to that but just wanted to get the potential false display of Rockstor installed version out of the way first. That threads contents should help though as it looks just like what you are experiencing.
Let us know how you get on with it’s suggestions.
Hey Philip,
I went through the thread you mentioned and found something.
When running(just some abstract):
" yum install libwbclient
–> Processing Dependency: libwbclient = 4.6.2-12.el7_4 for package: samba-4.6.2-12.el7_4.x86_64
—> Package libwbclient.x86_64 0:4.7.1-6.el7 will be an update
Error: Package: samba-4.6.2-12.el7_4.x86_64 (@updates)
Requires: libwbclient = 4.6.2-12.el7_4
Removing: libwbclient-4.6.2-12.el7_4.x86_64 (@updates)
Updated By: libwbclient-4.7.1-6.el7.x86_64 (base)
libwbclient = 4.7.1-6.el7 "
So the question is, how can reinstall libwclient 4.6.2 or how can I make samba running on libwclient 4.7.1
Thanks.
" yum reinstall libwbclient -y " delivers the following:
" Multilib version problems found. This often means that the root
cause is something else and multilib version checking is just
pointing out that there is a problem.
…you can also use --setopt=protected_multilib=false to remove
this checking, however this is almost never the correct thing to
do as something else is very likely to go wrong (often causing
much more problems).
Protected multilib versions: libwbclient-4.7.1-6.el7.x86_64 != libwbclient-4.6.2-12.el7_4.x86_64 "
an other interesting thing:
" yum list installed samba
Installed Packages
samba.x86_64 – 4.6.2-12.el7_4 – @updates
samba.x86_64 – 4.7.1-6.el7 – installed "
hm…
@Chavell3
Now that you are on Rockstor 3.9.2-31, what happens if you simply do:
yum update
well yes there where some new packages.
e.g.:
samba-client-4.7.1-6.el7.x86_64 is a duplicate with samba-client-4.6.2-12.el7_4.x86_64
samba-client-4.7.1-6 could probably solve my problem, but it seems it cannot be installed…
any idea on how to force to install 4.7.1?
Thanks
@Chavell3,
Can you share the full output from:
yum update
Thanks
@vesper1978 and @Chavell3 from the following:
along with:
It looks to me like we may have a scenario akin to the one addressed in:
https://wiki.centos.org/HowTos/CleaningUpDuplicatePackages
from that link we have:
"The problem
If a yum update run fails in some spectacular manner such as, but not limited to, your ssh session disconnecting in mid-update, yum being killed by the OOM killer, system powering off etc, then this can leave your system in an indeterminate state with two sets of packages installed. It is then impossible to run yum-complete-transaction or any new yum update as it complains about the duplicates."
agreed on:
the complete output is:
[root@rock-srv ~]# yum update
Rockstor-Stable | 2.9 kB 00:00:00
rockstor | 2.9 kB 00:00:00
Resolving Dependencies
There are unfinished transactions remaining. You might consider running yum-complete-transaction, or “yum-complete-transaction --cleanup-only” and “yum history redo last”, first to finish them. If those don’t work you’ll have to try removing/installing packages by hand (maybe package-cleanup can help).
The program yum-complete-transaction is found in the yum-utils package.
→ Running transaction check
—> Package ModemManager-glib.x86_64 0:1.6.0-2.el7 will be updated
—> Package ModemManager-glib.x86_64 0:1.6.10-1.el7 will be an update
—> Package NetworkManager-ppp.x86_64 1:1.8.0-11.el7_4 will be updated
—> Package NetworkManager-ppp.x86_64 1:1.10.2-16.el7_5 will be an update
—> Package NetworkManager-team.x86_64 1:1.8.0-11.el7_4 will be updated
—> Package NetworkManager-team.x86_64 1:1.10.2-16.el7_5 will be an update
—> Package NetworkManager-tui.x86_64 1:1.8.0-11.el7_4 will be updated
—> Package NetworkManager-tui.x86_64 1:1.10.2-16.el7_5 will be an update
—> Package OpenIPMI-modalias.x86_64 0:2.0.19-15.el7 will be updated
—> Package OpenIPMI-modalias.x86_64 0:2.0.23-2.el7 will be an update
—> Package adwaita-cursor-theme.noarch 0:3.22.0-1.el7 will be updated
—> Package adwaita-cursor-theme.noarch 0:3.26.0-1.el7 will be an update
—> Package adwaita-icon-theme.noarch 0:3.22.0-1.el7 will be updated
—> Package adwaita-icon-theme.noarch 0:3.26.0-1.el7 will be an update
—> Package audit.x86_64 0:2.7.6-3.el7 will be updated
—> Package audit.x86_64 0:2.8.1-3.el7 will be an update
—> Package audit-libs.i686 0:2.7.6-3.el7 will be updated
—> Package audit-libs.i686 0:2.8.1-3.el7 will be an update
—> Package augeas-libs.x86_64 0:1.4.0-2.el7_4.2 will be updated
—> Package augeas-libs.x86_64 0:1.4.0-5.el7_5.1 will be an update
—> Package avahi-glib.x86_64 0:0.6.31-17.el7 will be updated
—> Package avahi-glib.x86_64 0:0.6.31-19.el7 will be an update
—> Package bind-libs-lite.x86_64 32:9.9.4-51.el7_4.1 will be updated
—> Package bind-libs-lite.x86_64 32:9.9.4-61.el7 will be an update
—> Package bind-license.noarch 32:9.9.4-51.el7_4.1 will be updated
—> Package bind-license.noarch 32:9.9.4-61.el7 will be an update
—> Package biosdevname.x86_64 0:0.7.2-2.el7 will be updated
—> Package biosdevname.x86_64 0:0.7.3-1.el7 will be an update
—> Package certbot.noarch 0:0.19.0-1.el7 will be updated
—> Package certbot.noarch 0:0.25.1-3.el7 will be an update
—> Package checkpolicy.x86_64 0:2.5-4.el7 will be updated
—> Package checkpolicy.x86_64 0:2.5-6.el7 will be an update
—> Package container-selinux.noarch 2:2.33-1.git86f33cd.el7 will be updated
—> Package container-selinux.noarch 2:2.66-1.el7 will be an update
—> Package dhclient.x86_64 12:4.2.5-58.el7.centos will be updated
—> Package dhclient.x86_64 12:4.2.5-68.el7.centos.1 will be an update
—> Package dracut-config-rescue.x86_64 0:033-502.el7 will be updated
—> Package dracut-config-rescue.x86_64 0:033-535.el7 will be an update
—> Package dracut-network.x86_64 0:033-502.el7 will be updated
—> Package dracut-network.x86_64 0:033-535.el7 will be an update
—> Package e2fsprogs.x86_64 0:1.42.9-10.el7 will be updated
—> Package e2fsprogs.x86_64 0:1.42.9-12.el7_5 will be an update
—> Package elfutils-libelf.i686 0:0.168-8.el7 will be updated
—> Package elfutils-libelf.i686 0:0.170-4.el7 will be an update
—> Package elfutils-libs.i686 0:0.168-8.el7 will be updated
—> Package elfutils-libs.i686 0:0.170-4.el7 will be an update
—> Package firewalld.noarch 0:0.4.4.4-6.el7 will be updated
—> Package firewalld.noarch 0:0.4.4.4-14.el7 will be an update
—> Package firewalld-filesystem.noarch 0:0.4.4.4-6.el7 will be updated
—> Package firewalld-filesystem.noarch 0:0.4.4.4-14.el7 will be an update
—> Package fuse-libs.x86_64 0:2.9.2-8.el7 will be updated
—> Package fuse-libs.x86_64 0:2.9.2-10.el7 will be an update
—> Package gcc.x86_64 0:4.8.5-16.el7_4.1 will be updated
—> Package gcc.x86_64 0:4.8.5-28.el7_5.1 will be an update
—> Package glibc.i686 0:2.17-196.el7_4.2 will be updated
—> Package glibc.i686 0:2.17-222.el7 will be an update
—> Package glibc-devel.x86_64 0:2.17-196.el7_4.2 will be updated
—> Package glibc-devel.x86_64 0:2.17-222.el7 will be an update
—> Package glibc-headers.x86_64 0:2.17-196.el7_4.2 will be updated
—> Package glibc-headers.x86_64 0:2.17-222.el7 will be an update
—> Package gsettings-desktop-schemas.x86_64 0:3.22.0-1.el7 will be updated
—> Package gsettings-desktop-schemas.x86_64 0:3.24.1-2.el7_5 will be an update
—> Package gssproxy.x86_64 0:0.7.0-4.el7 will be updated
—> Package gssproxy.x86_64 0:0.7.0-17.el7 will be an update
—> Package gtk-vnc2.x86_64 0:0.7.0-2.el7 will be updated
—> Package gtk-vnc2.x86_64 0:0.7.0-3.el7 will be an update
—> Package gtk3.x86_64 0:3.22.10-5.el7_4 will be updated
—> Package gtk3.x86_64 0:3.22.26-4.el7_5 will be an update
→ Processing Dependency: libxkbcommon.so.0(V_0.5.0)(64bit) for package: gtk3-3.22.26-4.el7_5.x86_64
→ Processing Dependency: libxkbcommon.so.0()(64bit) for package: gtk3-3.22.26-4.el7_5.x86_64
→ Processing Dependency: libwayland-egl.so.1()(64bit) for package: gtk3-3.22.26-4.el7_5.x86_64
—> Package iprutils.x86_64 0:2.4.14.1-1.el7 will be updated
—> Package iprutils.x86_64 0:2.4.15.1-1.el7 will be an update
—> Package irqbalance.x86_64 3:1.0.7-10.el7 will be updated
—> Package irqbalance.x86_64 3:1.0.7-11.el7 will be an update
—> Package iwl100-firmware.noarch 0:39.31.5.1-56.el7 will be updated
—> Package iwl100-firmware.noarch 0:39.31.5.1-62.2.el7_5 will be an update
—> Package iwl1000-firmware.noarch 1:39.31.5.1-56.el7 will be updated
—> Package iwl1000-firmware.noarch 1:39.31.5.1-62.2.el7_5 will be an update
—> Package iwl105-firmware.noarch 0:18.168.6.1-56.el7 will be updated
—> Package iwl105-firmware.noarch 0:18.168.6.1-62.2.el7_5 will be an update
—> Package iwl135-firmware.noarch 0:18.168.6.1-56.el7 will be updated
—> Package iwl135-firmware.noarch 0:18.168.6.1-62.2.el7_5 will be an update
—> Package iwl2000-firmware.noarch 0:18.168.6.1-56.el7 will be updated
—> Package iwl2000-firmware.noarch 0:18.168.6.1-62.2.el7_5 will be an update
—> Package iwl2030-firmware.noarch 0:18.168.6.1-56.el7 will be updated
—> Package iwl2030-firmware.noarch 0:18.168.6.1-62.2.el7_5 will be an update
—> Package iwl3160-firmware.noarch 0:22.0.7.0-56.el7 will be updated
—> Package iwl3160-firmware.noarch 0:22.0.7.0-62.2.el7_5 will be an update
—> Package iwl3945-firmware.noarch 0:15.32.2.9-56.el7 will be updated
—> Package iwl3945-firmware.noarch 0:15.32.2.9-62.2.el7_5 will be an update
—> Package iwl4965-firmware.noarch 0:228.61.2.24-56.el7 will be updated
—> Package iwl4965-firmware.noarch 0:228.61.2.24-62.2.el7_5 will be an update
—> Package iwl5000-firmware.noarch 0:8.83.5.1_1-56.el7 will be updated
—> Package iwl5000-firmware.noarch 0:8.83.5.1_1-62.2.el7_5 will be an update
—> Package iwl5150-firmware.noarch 0:8.24.2.2-56.el7 will be updated
—> Package iwl5150-firmware.noarch 0:8.24.2.2-62.2.el7_5 will be an update
—> Package iwl6000-firmware.noarch 0:9.221.4.1-56.el7 will be updated
—> Package iwl6000-firmware.noarch 0:9.221.4.1-62.2.el7_5 will be an update
—> Package iwl6000g2a-firmware.noarch 0:17.168.5.3-56.el7 will be updated
—> Package iwl6000g2a-firmware.noarch 0:17.168.5.3-62.2.el7_5 will be an update
—> Package iwl6000g2b-firmware.noarch 0:17.168.5.2-56.el7 will be updated
—> Package iwl6000g2b-firmware.noarch 0:17.168.5.2-62.2.el7_5 will be an update
—> Package iwl6050-firmware.noarch 0:41.28.5.1-56.el7 will be updated
—> Package iwl6050-firmware.noarch 0:41.28.5.1-62.2.el7_5 will be an update
—> Package iwl7260-firmware.noarch 0:22.0.7.0-56.el7 will be updated
—> Package iwl7260-firmware.noarch 0:22.0.7.0-62.2.el7_5 will be an update
—> Package kexec-tools.x86_64 0:2.0.14-17.2.el7 will be updated
—> Package kexec-tools.x86_64 0:2.0.15-13.el7 will be an update
—> Package krb5-devel.x86_64 0:1.15.1-8.el7 will be updated
—> Package krb5-devel.x86_64 0:1.15.1-19.el7 will be an update
—> Package libattr.i686 0:2.4.46-12.el7 will be updated
—> Package libattr.i686 0:2.4.46-13.el7 will be an update
—> Package libcom_err-devel.x86_64 0:1.42.9-10.el7 will be updated
—> Package libcom_err-devel.x86_64 0:1.42.9-12.el7_5 will be an update
—> Package libcurl-devel.x86_64 0:7.29.0-42.el7_4.1 will be updated
—> Package libcurl-devel.x86_64 0:7.29.0-46.el7 will be an update
—> Package libdb.i686 0:5.3.21-20.el7 will be updated
—> Package libdb.i686 0:5.3.21-24.el7 will be an update
—> Package libgudev1.x86_64 0:219-42.el7_4.4 will be updated
—> Package libgudev1.x86_64 0:219-57.el7 will be an update
—> Package libibverbs.x86_64 0:13-7.el7 will be updated
—> Package libibverbs.x86_64 0:15-7.el7_5 will be an update
—> Package libini_config.x86_64 0:1.3.0-27.el7 will be updated
—> Package libini_config.x86_64 0:1.3.1-29.el7 will be an update
—> Package libpath_utils.x86_64 0:0.2.1-27.el7 will be updated
—> Package libpath_utils.x86_64 0:0.2.1-29.el7 will be an update
—> Package libproxy.x86_64 0:0.4.11-10.el7 will be updated
—> Package libproxy.x86_64 0:0.4.11-11.el7 will be an update
—> Package librdmacm.x86_64 0:13-7.el7 will be updated
—> Package librdmacm.x86_64 0:15-7.el7_5 will be an update
—> Package libreport-filesystem.x86_64 0:2.1.11-38.el7.centos will be updated
—> Package libreport-filesystem.x86_64 0:2.1.11-40.el7.centos will be an update
—> Package libselinux.i686 0:2.5-11.el7 will be updated
—> Package libselinux.i686 0:2.5-12.el7 will be an update
—> Package libselinux-devel.x86_64 0:2.5-11.el7 will be updated
—> Package libselinux-devel.x86_64 0:2.5-12.el7 will be an update
—> Package libsepol.i686 0:2.5-6.el7 will be updated
—> Package libsepol.i686 0:2.5-8.1.el7 will be an update
—> Package libsepol-devel.x86_64 0:2.5-6.el7 will be updated
—> Package libsepol-devel.x86_64 0:2.5-8.1.el7 will be an update
—> Package libstdc++.i686 0:4.8.5-16.el7_4.1 will be updated
—> Package libstdc++.i686 0:4.8.5-28.el7_5.1 will be an update
—> Package libteam.x86_64 0:1.25-5.el7 will be updated
—> Package libteam.x86_64 0:1.27-4.el7 will be an update
—> Package libvirt.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-config-network.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-config-network.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-config-nwfilter.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-config-nwfilter.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-driver-interface.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-driver-interface.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-driver-lxc.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-driver-lxc.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-driver-nodedev.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-driver-nodedev.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-driver-nwfilter.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-driver-nwfilter.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-driver-qemu.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-driver-qemu.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-driver-secret.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-driver-secret.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-driver-storage.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-driver-storage.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-driver-storage-core.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-driver-storage-core.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-driver-storage-disk.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-driver-storage-disk.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-driver-storage-gluster.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-driver-storage-gluster.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-driver-storage-iscsi.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-driver-storage-iscsi.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-driver-storage-logical.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-driver-storage-logical.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-driver-storage-mpath.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-driver-storage-mpath.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-driver-storage-rbd.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-driver-storage-rbd.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvirt-daemon-driver-storage-scsi.x86_64 0:3.9.0-14.el7_5.5 will be updated
—> Package libvirt-daemon-driver-storage-scsi.x86_64 0:3.9.0-14.el7_5.6 will be an update
—> Package libvorbis.x86_64 1:1.3.3-8.el7 will be updated
—> Package libvorbis.x86_64 1:1.3.3-8.el7.1 will be an update
—> Package linux-firmware.noarch 0:20170606-56.gitc990aae.el7 will be updated
—> Package linux-firmware.noarch 0:20180220-62.2.git6d51311.el7_5 will be an update
—> Package lsof.x86_64 0:4.87-4.el7 will be updated
—> Package lsof.x86_64 0:4.87-5.el7 will be an update
—> Package mdadm.x86_64 0:4.0-5.el7 will be updated
—> Package mdadm.x86_64 0:4.0-13.el7 will be an update
—> Package microcode_ctl.x86_64 2:2.1-22.el7 will be updated
—> Package microcode_ctl.x86_64 2:2.1-29.2.el7_5 will be an update
—> Package nfs-utils.x86_64 1:1.3.0-0.48.el7_4 will be updated
—> Package nfs-utils.x86_64 1:1.3.0-0.54.el7 will be an update
—> Package nginx.x86_64 1:1.12.2-1.el7 will be updated
—> Package nginx.x86_64 1:1.12.2-2.el7 will be an update
—> Package nginx-all-modules.noarch 1:1.12.2-1.el7 will be updated
—> Package nginx-all-modules.noarch 1:1.12.2-2.el7 will be an update
—> Package nginx-filesystem.noarch 1:1.12.2-1.el7 will be updated
—> Package nginx-filesystem.noarch 1:1.12.2-2.el7 will be an update
—> Package nginx-mod-http-geoip.x86_64 1:1.12.2-1.el7 will be updated
—> Package nginx-mod-http-geoip.x86_64 1:1.12.2-2.el7 will be an update
—> Package nginx-mod-http-image-filter.x86_64 1:1.12.2-1.el7 will be updated
—> Package nginx-mod-http-image-filter.x86_64 1:1.12.2-2.el7 will be an update
—> Package nginx-mod-http-perl.x86_64 1:1.12.2-1.el7 will be updated
—> Package nginx-mod-http-perl.x86_64 1:1.12.2-2.el7 will be an update
—> Package nginx-mod-http-xslt-filter.x86_64 1:1.12.2-1.el7 will be updated
—> Package nginx-mod-http-xslt-filter.x86_64 1:1.12.2-2.el7 will be an update
—> Package nginx-mod-mail.x86_64 1:1.12.2-1.el7 will be updated
—> Package nginx-mod-mail.x86_64 1:1.12.2-2.el7 will be an update
—> Package nginx-mod-stream.x86_64 1:1.12.2-1.el7 will be updated
—> Package nginx-mod-stream.x86_64 1:1.12.2-2.el7 will be an update
—> Package nss-softokn-freebl.i686 0:3.28.3-8.el7_4 will be updated
—> Package nss-softokn-freebl.i686 0:3.36.0-5.el7_5 will be an update
—> Package openssh-clients.x86_64 0:7.4p1-13.el7_4 will be updated
—> Package openssh-clients.x86_64 0:7.4p1-16.el7 will be an update
—> Package openssh-server.x86_64 0:7.4p1-13.el7_4 will be updated
—> Package openssh-server.x86_64 0:7.4p1-16.el7 will be an update
—> Package openssl-devel.x86_64 1:1.0.2k-8.el7 will be updated
—> Package openssl-devel.x86_64 1:1.0.2k-12.el7 will be an update
—> Package osinfo-db.noarch 0:20170423-2.el7 will be updated
—> Package osinfo-db.noarch 0:20170813-6.el7 will be an update
—> Package pam.i686 0:1.1.8-18.el7 will be updated
—> Package pam.i686 0:1.1.8-22.el7 will be an update
—> Package perl-Getopt-Long.noarch 0:2.40-2.el7 will be updated
—> Package perl-Getopt-Long.noarch 0:2.40-3.el7 will be an update
—> Package policycoreutils-python.x86_64 0:2.5-17.1.el7 will be updated
—> Package policycoreutils-python.x86_64 0:2.5-22.el7 will be an update
—> Package python-urllib3.noarch 0:1.10.2-3.el7 will be updated
—> Package python-urllib3.noarch 0:1.10.2-5.el7 will be an update
—> Package python2-acme.noarch 0:0.19.0-1.el7 will be updated
—> Package python2-acme.noarch 0:0.25.1-1.el7 will be an update
→ Processing Dependency: python2-six for package: python2-acme-0.25.1-1.el7.noarch
→ Processing Dependency: python2-requests for package: python2-acme-0.25.1-1.el7.noarch
—> Package python2-certbot.noarch 0:0.19.0-1.el7 will be updated
—> Package python2-certbot.noarch 0:0.25.1-3.el7 will be an update
—> Package qemu-kvm.x86_64 10:1.5.3-156.el7_5.2 will be updated
—> Package qemu-kvm.x86_64 10:1.5.3-156.el7_5.3 will be an update
—> Package rdma-core.i686 0:13-7.el7 will be updated
—> Package rdma-core.i686 0:15-7.el7_5 will be an update
—> Package rsyslog.x86_64 0:8.24.0-12.el7 will be updated
—> Package rsyslog.x86_64 0:8.24.0-16.el7_5.4 will be an update
—> Package seabios-bin.noarch 0:1.10.2-3.el7_4.1 will be updated
—> Package seabios-bin.noarch 0:1.11.0-2.el7 will be an update
—> Package setools-libs.x86_64 0:3.3.8-1.1.el7 will be updated
—> Package setools-libs.x86_64 0:3.3.8-2.el7 will be an update
—> Package spice-glib.x86_64 0:0.33-6.el7_4.1 will be updated
—> Package spice-glib.x86_64 0:0.34-3.el7_5.1 will be an update
—> Package spice-gtk3.x86_64 0:0.33-6.el7_4.1 will be updated
—> Package spice-gtk3.x86_64 0:0.34-3.el7_5.1 will be an update
—> Package sudo.x86_64 0:1.8.19p2-11.el7_4 will be updated
—> Package sudo.x86_64 0:1.8.19p2-14.el7_5 will be an update
—> Package system-config-kdump.noarch 0:2.0.13-16.el7.centos will be updated
—> Package system-config-kdump.noarch 0:2.0.13-20.el7.centos will be an update
—> Package systemd-libs.i686 0:219-42.el7_4.4 will be updated
—> Package systemd-libs.i686 0:219-57.el7 will be an update
→ Processing Dependency: liblz4.so.1 for package: systemd-libs-219-57.el7.i686
—> Package teamd.x86_64 0:1.25-5.el7 will be updated
—> Package teamd.x86_64 0:1.27-4.el7 will be an update
—> Package tracker.x86_64 0:1.10.5-4.el7 will be updated
—> Package tracker.x86_64 0:1.10.5-6.el7 will be an update
—> Package tuned.noarch 0:2.8.0-5.el7 will be updated
—> Package tuned.noarch 0:2.9.0-1.el7 will be an update
—> Package unbound-libs.x86_64 0:1.4.20-34.el7 will be updated
—> Package unbound-libs.x86_64 0:1.6.6-1.el7 will be an update
—> Package webkitgtk4.x86_64 0:2.14.7-3.el7 will be updated
—> Package webkitgtk4.x86_64 0:2.16.6-6.el7 will be an update
—> Package webkitgtk4-jsc.x86_64 0:2.14.7-3.el7 will be updated
—> Package webkitgtk4-jsc.x86_64 0:2.16.6-6.el7 will be an update
—> Package webkitgtk4-plugin-process-gtk2.x86_64 0:2.14.7-3.el7 will be updated
—> Package webkitgtk4-plugin-process-gtk2.x86_64 0:2.16.6-6.el7 will be an update
—> Package xfsprogs.x86_64 0:4.5.0-12.el7 will be updated
—> Package xfsprogs.x86_64 0:4.5.0-15.el7 will be an update
—> Package libxkbcommon.x86_64 0:0.7.1-1.el7 will be installed
→ Processing Dependency: xkeyboard-config for package: libxkbcommon-0.7.1-1.el7.x86_64
—> Package lz4.i686 0:1.7.5-2.el7 will be installed
—> Package mesa-libwayland-egl.x86_64 0:17.2.3-8.20171019.el7 will be installed
—> Package python2-requests.noarch 0:2.6.0-0.el7 will be installed
—> Package python2-six.noarch 0:1.9.0-0.el7 will be installed
—> Package xkeyboard-config.noarch 0:2.20-1.el7 will be installed
→ Processing Conflict: avahi-glib-0.6.31-19.el7.x86_64 conflicts avahi < 0.6.31-19.el7
→ Finished Dependency Resolution
Error: avahi-glib conflicts with avahi-0.6.31-17.el7.x86_64
You could try using --skip-broken to work around the problem
** Found 217 pre-existing rpmdb problem(s), ‘yum check’ output follows:
1:NetworkManager-1.10.2-16.el7_5.x86_64 is a duplicate with 1:NetworkManager-1.8.0-11.el7_4.x86_64
1:NetworkManager-glib-1.10.2-16.el7_5.x86_64 has installed conflicts NetworkManager-libnm < (‘1’, ‘1.10.2’, ‘16.el7_5’): 1:NetworkManager-libnm-1.8.0-11.el7_4.x86_64
1:NetworkManager-glib-1.10.2-16.el7_5.x86_64 is a duplicate with 1:NetworkManager-glib-1.8.0-11.el7_4.x86_64
1:NetworkManager-libnm-1.10.2-16.el7_5.x86_64 has installed conflicts NetworkManager-glib < (‘1’, ‘1.10.2’, ‘16.el7_5’): 1:NetworkManager-glib-1.8.0-11.el7_4.x86_64
1:NetworkManager-libnm-1.10.2-16.el7_5.x86_64 is a duplicate with 1:NetworkManager-libnm-1.8.0-11.el7_4.x86_64
acl-2.2.51-14.el7.x86_64 is a duplicate with acl-2.2.51-12.el7.x86_64
alsa-lib-1.1.4.1-2.el7.x86_64 is a duplicate with alsa-lib-1.1.3-3.el7.x86_64
at-3.1.13-23.el7.x86_64 is a duplicate with at-3.1.13-22.el7.x86_64
audit-libs-2.8.1-3.el7.x86_64 is a duplicate with audit-libs-2.7.6-3.el7.x86_64
audit-libs-python-2.8.1-3.el7.x86_64 is a duplicate with audit-libs-python-2.7.6-3.el7.x86_64
avahi-0.6.31-19.el7.x86_64 is a duplicate with avahi-0.6.31-17.el7.x86_64
avahi-glib-0.6.31-17.el7.x86_64 has installed conflicts avahi > (‘0’, ‘0.6.31’, ‘17.el7’): avahi-0.6.31-19.el7.x86_64
avahi-libs-0.6.31-19.el7.x86_64 is a duplicate with avahi-libs-0.6.31-17.el7.x86_64
bash-4.2.46-30.el7.x86_64 is a duplicate with bash-4.2.46-29.el7_4.x86_64
binutils-2.27-28.base.el7_5.1.x86_64 is a duplicate with binutils-2.25.1-32.base.el7_4.1.x86_64
ca-certificates-2018.2.22-70.0.el7_5.noarch is a duplicate with ca-certificates-2017.2.14-71.el7.noarch
chrony-3.2-2.el7.x86_64 is a duplicate with chrony-3.1-2.el7.centos.x86_64
coreutils-8.22-21.el7.x86_64 is a duplicate with coreutils-8.22-18.el7.x86_64
cpio-2.11-27.el7.x86_64 is a duplicate with cpio-2.11-25.el7_4.x86_64
cpp-4.8.5-28.el7_5.1.x86_64 is a duplicate with cpp-4.8.5-16.el7_4.1.x86_64
cronie-1.4.11-19.el7.x86_64 is a duplicate with cronie-1.4.11-17.el7.x86_64
cronie-anacron-1.4.11-19.el7.x86_64 is a duplicate with cronie-anacron-1.4.11-17.el7.x86_64
cryptsetup-1.7.4-4.el7.x86_64 is a duplicate with cryptsetup-1.7.4-3.el7_4.1.x86_64
cryptsetup-libs-1.7.4-4.el7.x86_64 is a duplicate with cryptsetup-libs-1.7.4-3.el7_4.1.x86_64
1:cups-libs-1.6.3-35.el7.x86_64 is a duplicate with 1:cups-libs-1.6.3-29.el7.x86_64
curl-7.29.0-46.el7.x86_64 is a duplicate with curl-7.29.0-42.el7_4.1.x86_64
cyrus-sasl-2.1.26-23.el7.x86_64 is a duplicate with cyrus-sasl-2.1.26-21.el7.x86_64
cyrus-sasl-gssapi-2.1.26-23.el7.x86_64 is a duplicate with cyrus-sasl-gssapi-2.1.26-21.el7.x86_64
cyrus-sasl-lib-2.1.26-23.el7.x86_64 is a duplicate with cyrus-sasl-lib-2.1.26-21.el7.x86_64
cyrus-sasl-plain-2.1.26-23.el7.x86_64 is a duplicate with cyrus-sasl-plain-2.1.26-21.el7.x86_64
7:device-mapper-1.02.146-4.el7.x86_64 is a duplicate with 7:device-mapper-1.02.140-8.el7.x86_64
7:device-mapper-event-1.02.146-4.el7.x86_64 is a duplicate with 7:device-mapper-event-1.02.140-8.el7.x86_64
7:device-mapper-event-libs-1.02.146-4.el7.x86_64 is a duplicate with 7:device-mapper-event-libs-1.02.140-8.el7.x86_64
7:device-mapper-libs-1.02.146-4.el7.x86_64 is a duplicate with 7:device-mapper-libs-1.02.140-8.el7.x86_64
device-mapper-persistent-data-0.7.3-3.el7.x86_64 is a duplicate with device-mapper-persistent-data-0.7.0-0.1.rc6.el7_4.1.x86_64
12:dhcp-common-4.2.5-68.el7.centos.1.x86_64 is a duplicate with 12:dhcp-common-4.2.5-58.el7.centos.x86_64
12:dhcp-libs-4.2.5-68.el7.centos.1.x86_64 is a duplicate with 12:dhcp-libs-4.2.5-58.el7.centos.x86_64
dnsmasq-2.76-5.el7.x86_64 is a duplicate with dnsmasq-2.76-2.el7_4.2.x86_64
dracut-033-535.el7.x86_64 is a duplicate with dracut-033-502.el7.x86_64
e2fsprogs-libs-1.42.9-12.el7_5.x86_64 is a duplicate with e2fsprogs-libs-1.42.9-10.el7.x86_64
ebtables-2.0.10-16.el7.x86_64 is a duplicate with ebtables-2.0.10-15.el7.x86_64
elfutils-default-yama-scope-0.170-4.el7.noarch is a duplicate with elfutils-default-yama-scope-0.168-8.el7.noarch
elfutils-libelf-0.170-4.el7.x86_64 is a duplicate with elfutils-libelf-0.168-8.el7.x86_64
elfutils-libs-0.170-4.el7.x86_64 is a duplicate with elfutils-libs-0.168-8.el7.x86_64
2:ethtool-4.8-7.el7.x86_64 is a duplicate with 2:ethtool-4.8-1.el7.x86_64
filesystem-3.2-25.el7.x86_64 is a duplicate with filesystem-3.2-21.el7.x86_64
freeipmi-1.5.7-2.el7.x86_64 is a duplicate with freeipmi-1.2.9-8.el7.x86_64
glib2-2.54.2-2.el7.x86_64 is a duplicate with glib2-2.50.3-3.el7.x86_64
glibc-2.17-222.el7.x86_64 is a duplicate with glibc-2.17-196.el7_4.2.x86_64
glibc-common-2.17-222.el7.x86_64 is a duplicate with glibc-common-2.17-196.el7_4.2.x86_64
glusterfs-3.8.4-53.el7.centos.x86_64 is a duplicate with glusterfs-3.8.4-18.4.el7.centos.x86_64
glusterfs-api-3.8.4-53.el7.centos.x86_64 is a duplicate with glusterfs-api-3.8.4-18.4.el7.centos.x86_64
glusterfs-cli-3.8.4-53.el7.centos.x86_64 is a duplicate with glusterfs-cli-3.8.4-18.4.el7.centos.x86_64
glusterfs-client-xlators-3.8.4-53.el7.centos.x86_64 is a duplicate with glusterfs-client-xlators-3.8.4-18.4.el7.centos.x86_64
glusterfs-libs-3.8.4-53.el7.centos.x86_64 is a duplicate with glusterfs-libs-3.8.4-18.4.el7.centos.x86_64
gnupg2-2.0.22-5.el7_5.x86_64 is a duplicate with gnupg2-2.0.22-4.el7.x86_64
gperftools-libs-2.6.1-1.el7.x86_64 is a duplicate with gperftools-libs-2.4-8.el7.x86_64
gtk-update-icon-cache-3.22.26-4.el7_5.x86_64 is a duplicate with gtk-update-icon-cache-3.22.10-5.el7_4.x86_64
gvnc-0.7.0-3.el7.x86_64 is a duplicate with gvnc-0.7.0-2.el7.x86_64
gzip-1.5-10.el7.x86_64 is a duplicate with gzip-1.5-9.el7.x86_64
hwdata-0.252-8.8.el7.x86_64 is a duplicate with hwdata-0.252-8.6.el7.x86_64
info-5.1-5.el7.x86_64 is a duplicate with info-5.1-4.el7.x86_64
initscripts-9.49.41-1.el7.x86_64 has installed conflicts redhat-release < (‘0’, ‘7.5’, ‘0.11’): rockstor-release-3-8.16.el7.x86_64
initscripts-9.49.41-1.el7.x86_64 is a duplicate with initscripts-9.49.39-1.el7.x86_64
iproute-4.11.0-14.el7.x86_64 is a duplicate with iproute-3.10.0-87.el7.x86_64
iptables-1.4.21-24.1.el7_5.x86_64 is a duplicate with iptables-1.4.21-18.2.el7_4.x86_64
iscsi-initiator-utils-6.2.0.874-7.el7.x86_64 is a duplicate with iscsi-initiator-utils-6.2.0.874-4.el7.x86_64
iscsi-initiator-utils-iscsiuio-6.2.0.874-7.el7.x86_64 is a duplicate with iscsi-initiator-utils-iscsiuio-6.2.0.874-4.el7.x86_64
kmod-20-21.el7.x86_64 is a duplicate with kmod-20-15.el7_4.6.x86_64
kmod-libs-20-21.el7.x86_64 is a duplicate with kmod-libs-20-15.el7_4.6.x86_64
kpartx-0.4.9-119.el7.x86_64 is a duplicate with kpartx-0.4.9-111.el7.x86_64
krb5-libs-1.15.1-19.el7.x86_64 is a duplicate with krb5-libs-1.15.1-8.el7.x86_64
krb5-workstation-1.15.1-19.el7.x86_64 is a duplicate with krb5-workstation-1.15.1-8.el7.x86_64
libacl-2.2.51-14.el7.x86_64 is a duplicate with libacl-2.2.51-12.el7.x86_64
libattr-2.4.46-13.el7.x86_64 is a duplicate with libattr-2.4.46-12.el7.x86_64
libbasicobjects-0.1.1-29.el7.x86_64 is a duplicate with libbasicobjects-0.1.1-27.el7.x86_64
libblkid-2.23.2-52.el7.x86_64 is a duplicate with libblkid-2.23.2-43.el7_4.2.x86_64
libcgroup-0.41-15.el7.x86_64 is a duplicate with libcgroup-0.41-13.el7.x86_64
libcollection-0.7.0-29.el7.x86_64 is a duplicate with libcollection-0.6.2-27.el7.x86_64
libcom_err-1.42.9-12.el7_5.x86_64 is a duplicate with libcom_err-1.42.9-10.el7.x86_64
libcurl-7.29.0-46.el7.x86_64 is a duplicate with libcurl-7.29.0-42.el7_4.1.x86_64
libdb-5.3.21-24.el7.x86_64 is a duplicate with libdb-5.3.21-20.el7.x86_64
libdb-utils-5.3.21-24.el7.x86_64 is a duplicate with libdb-utils-5.3.21-20.el7.x86_64
libdrm-2.4.83-2.el7.x86_64 is a duplicate with libdrm-2.4.74-1.el7.x86_64
libepoxy-1.3.1-2.el7_5.x86_64 is a duplicate with libepoxy-1.3.1-1.el7.x86_64
libgcc-4.8.5-28.el7_5.1.i686 is a duplicate with libgcc-4.8.5-16.el7_4.1.x86_64
libgomp-4.8.5-28.el7_5.1.x86_64 is a duplicate with libgomp-4.8.5-16.el7_4.1.x86_64
libkadm5-1.15.1-19.el7.x86_64 is a duplicate with libkadm5-1.15.1-8.el7.x86_64
libldb-1.2.2-1.el7.x86_64 is a duplicate with libldb-1.1.29-1.el7.x86_64
libmount-2.23.2-52.el7.x86_64 is a duplicate with libmount-2.23.2-43.el7_4.2.x86_64
libnfsidmap-0.25-19.el7.x86_64 is a duplicate with libnfsidmap-0.25-17.el7.x86_64
14:libpcap-1.5.3-11.el7.x86_64 is a duplicate with 14:libpcap-1.5.3-9.el7.x86_64
libpciaccess-0.14-1.el7.x86_64 is a duplicate with libpciaccess-0.13.4-3.1.el7_4.x86_64
libpwquality-1.2.3-5.el7.x86_64 is a duplicate with libpwquality-1.2.3-4.el7.x86_64
libref_array-0.1.5-29.el7.x86_64 is a duplicate with libref_array-0.1.5-27.el7.x86_64
libselinux-2.5-12.el7.x86_64 is a duplicate with libselinux-2.5-11.el7.x86_64
libselinux-python-2.5-12.el7.x86_64 is a duplicate with libselinux-python-2.5-11.el7.x86_64
libselinux-utils-2.5-12.el7.x86_64 is a duplicate with libselinux-utils-2.5-11.el7.x86_64
libsemanage-2.5-11.el7.x86_64 is a duplicate with libsemanage-2.5-8.el7.x86_64
libsemanage-python-2.5-11.el7.x86_64 is a duplicate with libsemanage-python-2.5-8.el7.x86_64
libsepol-2.5-8.1.el7.x86_64 is a duplicate with libsepol-2.5-6.el7.x86_64
libsmbclient-4.7.1-6.el7.x86_64 is a duplicate with libsmbclient-4.6.2-12.el7_4.x86_64
libsoup-2.56.0-6.el7.x86_64 is a duplicate with libsoup-2.56.0-4.el7_4.x86_64
libss-1.42.9-12.el7_5.x86_64 is a duplicate with libss-1.42.9-10.el7.x86_64
libstdc+±4.8.5-28.el7_5.1.x86_64 is a duplicate with libstdc+±4.8.5-16.el7_4.1.x86_64
libtalloc-2.1.10-1.el7.x86_64 is a duplicate with libtalloc-2.1.9-1.el7.x86_64
libtdb-1.3.15-1.el7.x86_64 is a duplicate with libtdb-1.3.12-2.el7.x86_64
libtevent-0.9.33-2.el7.x86_64 is a duplicate with libtevent-0.9.31-1.el7.x86_64
libusbx-1.0.21-1.el7.x86_64 is a duplicate with libusbx-1.0.20-1.el7.x86_64
libuser-0.60-9.el7.x86_64 is a duplicate with libuser-0.60-7.el7_1.x86_64
libuuid-2.23.2-52.el7.x86_64 is a duplicate with libuuid-2.23.2-43.el7_4.2.x86_64
libvirt-client-3.9.0-14.el7_5.6.x86_64 is a duplicate with libvirt-client-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-3.9.0-14.el7_5.6.x86_64 is a duplicate with libvirt-daemon-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-network-3.9.0-14.el7_5.6.x86_64 is a duplicate with libvirt-daemon-driver-network-3.9.0-14.el7_5.5.x86_64
libvirt-libs-3.9.0-14.el7_5.6.x86_64 is a duplicate with libvirt-libs-3.9.0-14.el7_5.5.x86_64
libwbclient-4.7.1-6.el7.x86_64 is a duplicate with libwbclient-4.6.2-12.el7_4.x86_64
logrotate-3.8.6-15.el7.x86_64 is a duplicate with logrotate-3.8.6-14.el7.x86_64
7:lvm2-2.02.177-4.el7.x86_64 is a duplicate with 7:lvm2-2.02.171-8.el7.x86_64
7:lvm2-libs-2.02.177-4.el7.x86_64 is a duplicate with 7:lvm2-libs-2.02.171-8.el7.x86_64
mailx-12.5-19.el7.x86_64 is a duplicate with mailx-12.5-16.el7.x86_64
mesa-libEGL-17.2.3-8.20171019.el7.x86_64 is a duplicate with mesa-libEGL-17.0.1-6.20170307.el7.x86_64
mesa-libGL-17.2.3-8.20171019.el7.x86_64 is a duplicate with mesa-libGL-17.0.1-6.20170307.el7.x86_64
mesa-libgbm-17.2.3-8.20171019.el7.x86_64 is a duplicate with mesa-libgbm-17.0.1-6.20170307.el7.x86_64
mesa-libglapi-17.2.3-8.20171019.el7.x86_64 is a duplicate with mesa-libglapi-17.0.1-6.20170307.el7.x86_64
mozjs17-17.0.0-20.el7.x86_64 is a duplicate with mozjs17-17.0.0-19.el7.x86_64
1:net-snmp-5.7.2-33.el7_5.2.x86_64 is a duplicate with 1:net-snmp-5.7.2-28.el7.x86_64
1:net-snmp-agent-libs-5.7.2-33.el7_5.2.x86_64 is a duplicate with 1:net-snmp-agent-libs-5.7.2-28.el7.x86_64
1:net-snmp-libs-5.7.2-33.el7_5.2.x86_64 is a duplicate with 1:net-snmp-libs-5.7.2-28.el7.x86_64
2:nmap-ncat-6.40-13.el7.x86_64 is a duplicate with 2:nmap-ncat-6.40-7.el7.x86_64
nspr-4.19.0-1.el7_5.x86_64 is a duplicate with nspr-4.13.1-1.0.el7_3.x86_64
nss-3.36.0-5.el7_5.x86_64 is a duplicate with nss-3.28.4-15.el7_4.x86_64
nss-softokn-3.36.0-5.el7_5.x86_64 is a duplicate with nss-softokn-3.28.3-8.el7_4.x86_64
nss-softokn-freebl-3.36.0-5.el7_5.x86_64 is a duplicate with nss-softokn-freebl-3.28.3-8.el7_4.x86_64
nss-sysinit-3.36.0-5.el7_5.x86_64 is a duplicate with nss-sysinit-3.28.4-15.el7_4.x86_64
nss-tools-3.36.0-5.el7_5.x86_64 is a duplicate with nss-tools-3.28.4-15.el7_4.x86_64
nss-util-3.36.0-1.el7_5.x86_64 is a duplicate with nss-util-3.28.4-3.el7.x86_64
ntp-4.2.6p5-28.el7.centos.x86_64 is a duplicate with ntp-4.2.6p5-25.el7.centos.2.x86_64
ntpdate-4.2.6p5-28.el7.centos.x86_64 is a duplicate with ntpdate-4.2.6p5-25.el7.centos.2.x86_64
numactl-libs-2.0.9-7.el7.x86_64 is a duplicate with numactl-libs-2.0.9-6.el7_2.x86_64
numad-0.5-18.20150602git.el7.x86_64 is a duplicate with numad-0.5-17.20150602git.el7.x86_64
nut-2.7.2-4.el7.x86_64 is a duplicate with nut-2.7.2-3.el7.x86_64
nut-client-2.7.2-4.el7.x86_64 is a duplicate with nut-client-2.7.2-3.el7.x86_64
nut-xml-2.7.2-4.el7.x86_64 is a duplicate with nut-xml-2.7.2-3.el7.x86_64
openldap-2.4.44-15.el7_5.x86_64 is a duplicate with openldap-2.4.44-5.el7.x86_64
openssh-7.4p1-16.el7.x86_64 is a duplicate with openssh-7.4p1-13.el7_4.x86_64
1:openssl-1.0.2k-12.el7.x86_64 is a duplicate with 1:openssl-1.0.2k-8.el7.x86_64
1:openssl-libs-1.0.2k-12.el7.x86_64 is a duplicate with 1:openssl-libs-1.0.2k-8.el7.x86_64
pam-1.1.8-22.el7.x86_64 is a duplicate with pam-1.1.8-18.el7.x86_64
parted-3.1-29.el7.x86_64 is a duplicate with parted-3.1-28.el7.x86_64
pciutils-3.5.1-3.el7.x86_64 is a duplicate with pciutils-3.5.1-2.el7.x86_64
pciutils-libs-3.5.1-3.el7.x86_64 is a duplicate with pciutils-libs-3.5.1-2.el7.x86_64
plymouth-0.8.9-0.31.20140113.el7.centos.x86_64 is a duplicate with plymouth-0.8.9-0.28.20140113.el7.centos.x86_64
plymouth-core-libs-0.8.9-0.31.20140113.el7.centos.x86_64 is a duplicate with plymouth-core-libs-0.8.9-0.28.20140113.el7.centos.x86_64
plymouth-scripts-0.8.9-0.31.20140113.el7.centos.x86_64 is a duplicate with plymouth-scripts-0.8.9-0.28.20140113.el7.centos.x86_64
policycoreutils-2.5-22.el7.x86_64 is a duplicate with policycoreutils-2.5-17.1.el7.x86_64
polkit-0.112-14.el7.x86_64 is a duplicate with polkit-0.112-12.el7_3.x86_64
procps-ng-3.3.10-17.el7_5.2.x86_64 is a duplicate with procps-ng-3.3.10-16.el7.x86_64
pulseaudio-libs-10.0-5.el7.x86_64 is a duplicate with pulseaudio-libs-10.0-3.el7.x86_64
pulseaudio-libs-glib2-10.0-5.el7.x86_64 is a duplicate with pulseaudio-libs-glib2-10.0-3.el7.x86_64
pytalloc-2.1.10-1.el7.x86_64 is a duplicate with pytalloc-2.1.9-1.el7.x86_64
python-2.7.5-69.el7_5.x86_64 is a duplicate with python-2.7.5-58.el7.x86_64
python-backports-ssl_match_hostname-3.5.0.1-1.el7.noarch is a duplicate with python-backports-ssl_match_hostname-3.4.0.2-4.el7.noarch
python-firewall-0.4.4.4-14.el7.noarch is a duplicate with python-firewall-0.4.4.4-6.el7.noarch
python-libs-2.7.5-69.el7_5.x86_64 is a duplicate with python-libs-2.7.5-58.el7.x86_64
python-slip-0.4.0-4.el7.noarch is a duplicate with python-slip-0.4.0-2.el7.noarch
python-slip-dbus-0.4.0-4.el7.noarch is a duplicate with python-slip-dbus-0.4.0-2.el7.noarch
python2-cryptography-1.7.2-2.el7.x86_64 is a duplicate with python2-cryptography-1.7.2-1.el7_4.1.x86_64
python2-future-0.16.0-6.el7.noarch is a duplicate with python2-future-0.16.0-2.el7.noarch
10:qemu-img-1.5.3-156.el7_5.3.x86_64 is a duplicate with 10:qemu-img-1.5.3-156.el7_5.2.x86_64
10:qemu-kvm-common-1.5.3-156.el7_5.3.x86_64 is a duplicate with 10:qemu-kvm-common-1.5.3-156.el7_5.2.x86_64
1:quota-4.01-17.el7.x86_64 is a duplicate with 1:quota-4.01-14.el7.x86_64
1:quota-nls-4.01-17.el7.noarch is a duplicate with 1:quota-nls-4.01-14.el7.noarch
radvd-1.9.2-9.el7_5.4.x86_64 is a duplicate with radvd-1.9.2-9.el7.x86_64
rdma-core-15-7.el7_5.x86_64 is a duplicate with rdma-core-13-7.el7.x86_64
rest-0.8.0-2.el7.x86_64 is a duplicate with rest-0.8.0-1.el7.x86_64
rockstor-release-3-9.23.el7.x86_64 is a duplicate with rockstor-release-3-8.16.el7.x86_64
rpcbind-0.2.0-44.el7.x86_64 is a duplicate with rpcbind-0.2.0-42.el7.x86_64
rpm-4.11.3-32.el7.x86_64 is a duplicate with rpm-4.11.3-25.el7.x86_64
rpm-build-libs-4.11.3-32.el7.x86_64 is a duplicate with rpm-build-libs-4.11.3-25.el7.x86_64
rpm-libs-4.11.3-32.el7.x86_64 is a duplicate with rpm-libs-4.11.3-25.el7.x86_64
rpm-python-4.11.3-32.el7.x86_64 is a duplicate with rpm-python-4.11.3-25.el7.x86_64
rsync-3.1.2-4.el7.x86_64 is a duplicate with rsync-3.0.9-18.el7.x86_64
samba-4.7.1-6.el7.x86_64 is a duplicate with samba-4.6.2-12.el7_4.x86_64
samba-client-libs-4.7.1-6.el7.x86_64 is a duplicate with samba-client-libs-4.6.2-12.el7_4.x86_64
samba-common-4.7.1-6.el7.noarch is a duplicate with samba-common-4.6.2-12.el7_4.noarch
samba-common-libs-4.7.1-6.el7.x86_64 is a duplicate with samba-common-libs-4.6.2-12.el7_4.x86_64
samba-common-tools-4.7.1-6.el7.x86_64 is a duplicate with samba-common-tools-4.6.2-12.el7_4.x86_64
samba-libs-4.7.1-6.el7.x86_64 is a duplicate with samba-libs-4.6.2-12.el7_4.x86_64
samba-winbind-4.7.1-6.el7.x86_64 is a duplicate with samba-winbind-4.6.2-12.el7_4.x86_64
samba-winbind-clients-4.7.1-6.el7.x86_64 is a duplicate with samba-winbind-clients-4.6.2-12.el7_4.x86_64
samba-winbind-krb5-locator-4.7.1-6.el7.x86_64 is a duplicate with samba-winbind-krb5-locator-4.6.2-12.el7_4.x86_64
samba-winbind-modules-4.7.1-6.el7.x86_64 is a duplicate with samba-winbind-modules-4.6.2-12.el7_4.x86_64
seavgabios-bin-1.11.0-2.el7.noarch is a duplicate with seavgabios-bin-1.10.2-3.el7_4.1.noarch
selinux-policy-3.13.1-192.el7_5.4.noarch is a duplicate with selinux-policy-3.13.1-166.el7_4.7.noarch
selinux-policy-targeted-3.13.1-192.el7_5.4.noarch is a duplicate with selinux-policy-targeted-3.13.1-166.el7_4.7.noarch
setup-2.8.71-9.el7.noarch is a duplicate with setup-2.8.71-7.el7.noarch
shared-mime-info-1.8-4.el7.x86_64 is a duplicate with shared-mime-info-1.8-3.el7.x86_64
shellinabox-2.20-5.el7.x86_64 is a duplicate with shellinabox-2.20-1.el7.x86_64
1:smartmontools-6.5-1.el7.x86_64 is a duplicate with 1:smartmontools-6.2-8.el7.x86_64
sos-3.5-9.el7.centos.noarch is a duplicate with sos-3.4-6.el7.centos.noarch
spice-server-0.14.0-2.el7_5.4.x86_64 is a duplicate with spice-server-0.12.8-2.el7.1.x86_64
systemd-219-57.el7.x86_64 is a duplicate with systemd-219-42.el7_4.4.x86_64
systemd-libs-219-57.el7.x86_64 is a duplicate with systemd-libs-219-42.el7_4.4.x86_64
systemd-sysv-219-57.el7.x86_64 is a duplicate with systemd-sysv-219-42.el7_4.4.x86_64
systemtap-runtime-3.2-8.el7_5.x86_64 is a duplicate with systemtap-runtime-3.1-4.el7_4.x86_64
2:tar-1.26-34.el7.x86_64 is a duplicate with 2:tar-1.26-32.el7.x86_64
tzdata-2018e-3.el7.noarch is a duplicate with tzdata-2017c-1.el7.noarch
usbredir-0.7.1-3.el7.x86_64 is a duplicate with usbredir-0.7.1-2.el7.x86_64
util-linux-2.23.2-52.el7.x86_64 is a duplicate with util-linux-2.23.2-43.el7_4.2.x86_64
2:vim-minimal-7.4.160-4.el7.x86_64 is a duplicate with 2:vim-minimal-7.4.160-2.el7.x86_64
virt-what-1.18-4.el7.x86_64 is a duplicate with virt-what-1.13-10.el7.x86_64
1:wpa_supplicant-2.6-9.el7.x86_64 is a duplicate with 1:wpa_supplicant-2.6-5.el7_4.1.x86_64
yum-3.4.3-158.el7.centos.noarch is a duplicate with yum-3.4.3-154.el7.centos.noarch
yum-cron-3.4.3-158.el7.centos.noarch is a duplicate with yum-cron-3.4.3-154.el7.centos.noarch
yum-plugin-changelog-1.1.31-45.el7.noarch is a duplicate with yum-plugin-changelog-1.1.31-42.el7.noarch
yum-plugin-fastestmirror-1.1.31-45.el7.noarch is a duplicate with yum-plugin-fastestmirror-1.1.31-42.el7.noarch
the rest of the output.
Thanks Jason
many duplicate packages it seems… :frowning:
so whats your opinion, should I run
package-cleanup --dupes
to clean up the package information ?
@Chavell3, I’d suggest looking at the link @phillxnet provided earlier regarding the duplicate packages.
hey Guys,
OK I ran the command
package-cleanup --dupes --removenewestdupes
(package-cleanup --removenewestdupes // that command did not worked)
and it gives the following output
Loaded plugins: fastestmirror
libgcc-4.8.5-28.el7_5.1.x86_64
libgcc-4.8.5-16.el7_4.1.i686
But if run yum list ist still gave me both packages…
But from the centos wiki that command should have done all the cleanup… So I think I have to go the manual way for the cleanup… right?
Installed Packages
thanks for your support!!!
@Chavell3, yes it looks like you will need to remove the dupes manually.
