Scheduled scrub throws an error
This morning a mail from Rockstor was in my inbox.
Not the usual kind, but containing this:
Subject:
Cron root@rockstornas /opt/rockstor//bin/st-pool-scrub 2 *-----*
Content:
File “/usr/lib64/python2.7/logging/handlers.py”, line 76, in emit
if self.shouldRollover(record):
File “/usr/lib64/python2.7/logging/handlers.py”, line 154, in shouldRollover
msg = “%s\n” % self.format(record)
File “/usr/lib64/python2.7/logging/init.py”, line 724, in format
return fmt.format(record)
File “/usr/lib64/python2.7/logging/init.py”, line 464, in format
record.message = record.getMessage()
File “/usr/lib64/python2.7/logging/init.py”, line 324, in getMessage
msg = str(self.msg)
TypeError: str returned non-string (type list)
Logged from file pool_scrub.py, line 78
msg = str(self.msg)
Logged from file pool_scrub.py, line 39
Something seems to have gone wrong, and the scrub is not running.
This has been working perfectly for as long as I have used scheduled scrubs, so something must have changed with one of the later updates.
Hi @KarstenV,
can you scheduled a new scrub task and test it?
Thanks
Mirko
I just set up at scheduled scrub, to test if it would work.
It ended up like this:
Immediately after this failed I got a mail from Rockstor containing this:
Subj: Cron root@rockstornas /opt/rockstor//bin/st-pool-scrub 3 *-----*
Contents:
msg = str(self.msg)
msg = str(self.msg)
Oh, I probably should mention that I’m on the latest development build 3.9.0-16
Anybody have any ideas.
Is anybody else seing this?
Hi @KarstenV,
that’s quite strange, your crontab string seems not getting escaped, will check it
M.
Looking into this, the error is being caused by pool_scrub.py trying to log an APIException, changing lines 39 and 78 to:
logger.exception(e.detail)
allows the script to complete without error, afterwards in my log I see this:
[u'Invalid api end point: http://127.0.0.1:8000/api/pools/Primary/scrub']
[u'Invalid api end point: http://127.0.0.1:8000/api/pools/Primary/scrub/status']
Someone change the REST api recently?
@kbogert Hello again and nice find.
We have recently changed the pools and disks API’s from using their name field to using their db id. Looks like this got missed; oops.
Ie: For the pools #1741, and for the disks #1746 with a small associated follow up #1751
Do you fancy opening a GitHub issue on this in our rockstor-core repo as it would be a great one to get sorted? And of course if you fancy having a go at a fix by way of a pull request for it that would be great; just note your intention to do so in the issue as that should help avoid duplication of effort as this should be a pretty high priority to fix. Know we know whats going wrong. :slight_smile: Otherwise I can have a look shortly hopefully.
Thanks @kbogert, @KarstenV, and @Flyer, looks like you’ve rounded this one out in the end.
@KarstenV, @kbogert, and @Flyer
I’ve just submitted a pull request to address this issue. It is awaiting review and further testing but looks good so far. Turned out to be a little more complicate than I had at first hoped. Oh well.
Linking to @kbogert issue:
and the associated pull request:
Lets hope that helps.
Looks good @phillxnet.
I look forward to testing the fixes when they get released :slight_smile:
Thanks to @phillxnet for pitching in on this :slight_smile:
Mirko
@KarstenV @kbogert and @Flyer
Notification post: the fix for this issue has now been merged and released via the testing channel updates:
Thanks all for helping to resolve this one.
Looks good, I had to delete all of my scheduled scrubs and re-create them which was a minor annoyance.
Thanks all!
@kbogert Thanks for the feedback / fix confirmation and glad you are now sorted:
Yes, that is a bit of a pain point. Sorry I should have emphasise that element of the fix.
Thanks again for helping to diagnose this one.
