Went to change from DHCP to manual and got the following error. Oddly enough if I go back in to do the same steps then the original DHCP IP address is in the IP field followed by the IP address I tried to manually assign:
drill down to system → network → wired connection 1 then click the
File "/opt/rockstor/src/rockstor/storageadmin/views/network.py", line 534, in put
return Response(NetworkConnectionSerializer(nco).data)
File "/opt/rockstor/.venv/lib/python3.11/site-packages/rest_framework/serializers.py", line 571, in data
ret = super().data
File "/opt/rockstor/.venv/lib/python3.11/site-packages/rest_framework/serializers.py", line 249, in data
self._data = self.to_representation(self.instance)
File "/opt/rockstor/.venv/lib/python3.11/site-packages/rest_framework/serializers.py", line 525, in to_representation
attribute = field.get_attribute(instance)
File "/opt/rockstor/.venv/lib/python3.11/site-packages/rest_framework/fields.py", line 437, in get_attribute
return get_attribute(instance, self.source_attrs)
File "/opt/rockstor/.venv/lib/python3.11/site-packages/rest_framework/fields.py", line 104, in get_attribute
instance = getattr(instance, attr)
File "/opt/rockstor/src/rockstor/storageadmin/models/network_interface.py", line 81, in ctype
if self.ethernetconnection_set.count() > 0:
File "/opt/rockstor/.venv/lib/python3.11/site-packages/django/db/models/manager.py", line 87, in manager_method
File "/opt/rockstor/.venv/lib/python3.11/site-packages/django/db/models/fields/related_descriptors.py", line 718, in get_queryset
raise ValueError(
ValueError: 'NetworkConnection' instance needs to have a primary key value before this relationship can be used.
I have encountered this issue, I ended up leaving it at auto config, and set my router to assign a IP address “static” to the MAC address in my NAS network card. Now if I have to reinstall RS it always selects the same IP address
