I cannot load amdgpu driver.
My config is a AMD Ryzen 2500u APU on RockStor 5.0.13-0, openSUSE Leap: 15.6, Linux: 6.4.0-150600.23.17-default
inxi -G
Graphics:
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series] driver: N/A
Device-2: Quanta VGA WebCam driver: uvcvideo type: USB
Display: server: X.org v: 1.21.1.11 driver: N/A tty: 116x55
API: OpenGL Message: GL data unavailable in console and glxinfo missing.
lspci -k | grep -A 3 -i vga
03:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] (rev c4)
Subsystem: Acer Incorporated [ALI] Device 1259
Kernel modules: amdgpu
03:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
I followed this install instruction: SDB:AMDGPU - openSUSE Wiki
zypper install kernel-firmware-amdgpu
and tried to remove nomodeset from boot options by editing /etc/default/grub
Then i did grub2-mkconfig -o /boot/grub2/grub.cfg
, dracut --force
and reboot
lsmod | grep amdgpu
outputs nothing, so the driver is not loaded
modprobe -v amdgpu
insmod /lib/modules/6.4.0-150600.23.17-default/kernel/drivers/gpu/drm/amd/amdgpu/amdgpu.ko.zst
modprobe: ERROR: could not insert 'amdgpu': Invalid argument
ls /dev/dri
ls: cannot access '/dev/dri': No such file or directory
I also tested with a openSuse Leap 15.6 KDE install on a external drive and it did load the amdgpu driver. It had the kernel-firmware-amdgpu
package and no special kernel config.
At the end i want hardware acceleration with VAAPI on Frigate Hardware Acceleration | Frigate
