Upgraded both NAS setups to 5.0.10 without a hitch, then today tried to PuTTY into them on port 22 and using either root or admin login, it won’t connect.
Both setups perform perfectly and the Rockstor web GUI works fine on both.
When I installed 5.0.9 and then updated to 5.0.10 on the 192.168.1.104 setup, I also changed the password so it would match the new password of my .108 setup.
So, on the .104 setup, it uses the NEW password on the Web GUI, but weirdly uses the OLD password using PuTTY!!!
GO figure… I will try a new reinstall of 5.0.9 then upgrade it unless there is a way to fix the weird root password thing…
PS: Both setups used to have different PW’s, but I wanted them the same this time around… is it stored somewhere on the disk images or something?
