Tried to ‘upgrade’ a NextCloud Rockon (that wraps the undeadhunter/nextcloud-letsencrypt docker container), by uninstall/install the rockon.
As it did not have any effect, I thought a reboot of the server would not hurt.
But the webui would not start any more.
Checking which services failed it showed the that the rockstor-pre.service had failed.
Looking into that it showed that the initrock python script had failed:
[root@rocky rockons-metastore]# /opt/rockstor/bin/initrock
2017-04-20 02:07:18,373: Supported kernel(/boot/vmlinuz-4.10.6-1.el7.elrepo.x86_64) is already the default
2017-04-20 02:07:18,605: /etc/rc.d/rc.local looks correct. Not updating.
2017-04-20 02:07:18,606: Checking for flash and Running flash optimizations if appropriate.
2017-04-20 02:07:20,816: Updating the timezone from the system
2017-04-20 02:07:20,817: system timezone = Europe/Berlin
2017-04-20 02:07:20,820: Changed timezone from America/Chicago to Europe/Berlin
2017-04-20 02:07:20,826: Updating sshd_config
2017-04-20 02:07:20,830: sshd_config already has the updates. Leaving it unchanged.
2017-04-20 02:07:20,831: Running app database migrations…
File “/opt/rockstor/bin/initrock”, line 45, in
sys.exit(scripts.initrock.main())
File “/opt/rockstor/src/rockstor/scripts/initrock.py”, line 421, in main
run_command(migration_cmd + [‘storageadmin’])
File “/opt/rockstor/src/rockstor/system/osi.py”, line 114, in run_command
system.exceptions.CommandException: Error running a command. cmd = /opt/rockstor/bin/django migrate --noinput storageadmin. rc = 1. stdout = [‘Operations to perform:’, ’ Apply all migrations: storageadmin’, ‘Running migrations:’, ’ Rendering model states… DONE’, ’ Applying storageadmin.0003_auto_20170114_1332…’]. stderr = [‘Traceback (most recent call last):’, ’ File “/opt/rockstor/bin/django”, line 44, in ‘, " sys.exit(djangorecipe.manage.main(‘rockstor.settings’))", ’ File “/opt/rockstor/eggs/djangorecipe-1.9-py2.7.egg/djangorecipe/manage.py”, line 9, in main’, ’ management.execute_from_command_line(sys.argv)’, ’ File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/core/management/init.py”, line 354, in execute_from_command_line’, ’ utility.execute()’, ’ File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/core/management/init.py”, line 346, in execute’, ’ self.fetch_command(subcommand).run_from_argv(self.argv)’, ’ File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/core/management/base.py”, line 394, in run_from_argv’, ’ self.execute(*args, **cmd_options)’, ’ File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/core/management/base.py”, line 445, in execute’, ’ output = self.handle(*args, **options)’, ’ File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/core/management/commands/migrate.py”, line 222, in handle’, ’ executor.migrate(targets, plan, fake=fake, fake_initial=fake_initial)’, ’ File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/migrations/executor.py”, line 110, in migrate’, ’ self.apply_migration(states[migration], migration, fake=fake, fake_initial=fake_initial)’, ’ File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/migrations/executor.py”, line 148, in apply_migration’, ’ state = migration.apply(state, schema_editor)’, ’ File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/migrations/migration.py”, line 115, in apply’, ’ operation.database_forwards(self.app_label, schema_editor, old_state, project_state)’, ’ File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/migrations/operations/fields.py”, line 62, in database_forwards’, ’ field,’, ’ File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/backends/postgresql_psycopg2/schema.py”, line 18, in add_field’, ’ super(DatabaseSchemaEditor, self).add_field(model, field)’, ’ File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/backends/base/schema.py”, line 398, in add_field’, ’ self.execute(sql, params)’, ’ File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/backends/base/schema.py”, line 111, in execute’, ’ cursor.execute(sql, params)’, ’ File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/backends/utils.py”, line 64, in execute’, ’ return self.cursor.execute(sql, params)’, ’ File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/utils.py”, line 98, in exit’, ’ six.reraise(dj_exc_type, dj_exc_value, traceback)’, ’ File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/backends/utils.py”, line 64, in execute’, ’ return self.cursor.execute(sql, params)’, ‘django.db.utils.ProgrammingError: column “pqgroup_eusage” of relation “storageadmin_share” already exists’, ‘’, ‘’]
looks to me like it tries to make sure that its own postgres database schema is up to date, and then has problems applying changes (aka add a field to a relation that already exists).
What should I do?
