I really want to understand how the snapshots rollback works, I can’t rollback to a snapshot form webui, also the share isn’t exported via samba
Try to rollback to any of the snapshots
File "/opt/rockstor/src/rockstor/storageadmin/views/share_command.py", line 78, in post
share.pool)
File "/opt/rockstor/src/rockstor/fs/btrfs.py", line 627, in rollback_snap
remove_share(pool, subvol_name, '-1/-1')
File "/opt/rockstor/src/rockstor/fs/btrfs.py", line 547, in remove_share
run_command(delete_cmd, log=True)
File "/opt/rockstor/src/rockstor/system/osi.py", line 109, in run_command
CommandException: Error running a command. cmd = ['/sbin/btrfs', 'subvolume', 'delete', '/mnt2/NasPool/Rockon_Settings']. rc = 1. stdout = ["Delete subvolume (no-commit): '/mnt2/NasPool/Rockon_Settings'", '']. stderr = ["ERROR: cannot delete '/mnt2/NasPool/Rockon_Settings': Directory not empty", '']
Is this normal practice to produce this error saying directory isn’t empty? Am I supposed to delete the the content in the share and try the rollback? And if this is the case, do you guys think its reasonable to delete the content in order of performing a rollback?
Thanks folks
