Today I (re-)install Rockstor 3.8.15 from ISO DVD to USB stick and done.
I can logon via another PC with Firefox and Chromium. But Web-UI doesn’t show contents.
Nginx is seems working and I can not imagine what is happening to me. Someone help me out?
I’d tested with Firefox and Chromium on Fedora 24.
[root@rockstor ~]# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 931.5G 0 disk
└─sda1 8:1 0 931.5G 0 part
sdb 8:16 0 931.5G 0 disk
└─sdb1 8:17 0 931.5G 0 part
sdc 8:32 0 931.5G 0 disk
└─sdc1 8:33 0 931.5G 0 part
sdd 8:48 0 931.5G 0 disk
└─sdd1 8:49 0 931.5G 0 part
sde 8:64 1 29.3G 0 disk
├─sde1 8:65 1 200M 0 part /boot/efi
├─sde2 8:66 1 500M 0 part /boot
└─sde3 8:67 1 28.7G 0 part
├─rockstor_rockstor-swap 253:0 0 3G 0 lvm [SWAP]
└─rockstor_rockstor-root 253:1 0 25.7G 0 lvm /
[root@rockstor ~]# systemctl status -l rockstor
Active: active (running) since 土 2016-11-26 14:13:27 JST; 17min ago
Main PID: 2900 (supervisord)
├─2900 /usr/bin/python /opt/rockstor/bin/supervisord -c /opt/rockstor/etc/supervisord.conf
├─2911 nginx: master process /usr/sbin/nginx -c /opt/rockstor/etc/nginx/nginx.con
├─2912 /usr/bin/python /opt/rockstor/bin/gunicorn --bind=127.0.0.1:8000 --pid=/run/gunicorn.pid --workers=2 --log-file=/opt/rockstor/var/log/gunicorn.log --pythonpath=/opt/rockstor/src/rockstor --settings=settings --timeout=120 --graceful-timeout=120 wsgi:application
├─2913 /usr/bin/python /opt/rockstor/bin/data-collector
├─2914 /usr/bin/python2.7 /opt/rockstor/bin/django ztaskd --noreload --replayfailed -f /opt/rockstor/var/log/ztask.log
├─2916 nginx: worker process
├─2917 nginx: worker process
├─2927 /usr/bin/python /opt/rockstor/bin/gunicorn --bind=127.0.0.1:8000 --pid=/run/gunicorn.pid --workers=2 --log-file=/opt/rockstor/var/log/gunicorn.log --pythonpath=/opt/rockstor/src/rockstor --settings=settings --timeout=120 --graceful-timeout=120 wsgi:application
└─2928 /usr/bin/python /opt/rockstor/bin/gunicorn --bind=127.0.0.1:8000 --pid=/run/gunicorn.pid --workers=2 --log-file=/opt/rockstor/var/log/gunicorn.log --pythonpath=/opt/rockstor/src/rockstor --settings=settings --timeout=120 --graceful-timeout=120 wsgi:application
11月 26 14:13:28 rockstor.local supervisord[2900]: 2016-11-26 14:13:28,625 CRIT Server ‘unix_http_server’ running without any HTTP authentication checking
11月 26 14:13:28 rockstor.local supervisord[2900]: 2016-11-26 14:13:28,627 INFO supervisord started with pid 2900
11月 26 14:13:29 rockstor.local supervisord[2900]: 2016-11-26 14:13:29,657 INFO spawned: ‘nginx’ with pid 2911
11月 26 14:13:29 rockstor.local supervisord[2900]: 2016-11-26 14:13:29,710 INFO spawned: ‘gunicorn’ with pid 2912
11月 26 14:13:29 rockstor.local supervisord[2900]: 2016-11-26 14:13:29,773 INFO spawned: ‘data-collector’ with pid 2913
11月 26 14:13:29 rockstor.local supervisord[2900]: 2016-11-26 14:13:29,851 INFO spawned: ‘ztask-daemon’ with pid 2914
11月 26 14:13:31 rockstor.local supervisord[2900]: 2016-11-26 14:13:31,946 INFO success: data-collector entered RUNNING state, process has stayed up for > than 2 seconds (startsecs)
11月 26 14:13:31 rockstor.local supervisord[2900]: 2016-11-26 14:13:31,949 INFO success: ztask-daemon entered RUNNING state, process has stayed up for > than 2 seconds (startsecs)
11月 26 14:13:34 rockstor.local supervisord[2900]: 2016-11-26 14:13:34,953 INFO success: nginx entered RUNNING state, process has stayed up for > than 5 seconds (startsecs)
11月 26 14:13:34 rockstor.local supervisord[2900]: 2016-11-26 14:13:34,954 INFO success: gunicorn entered RUNNING state, process has stayed up for > than 5 seconds (startsecs)
Yukimi (weekend only)
