Samba service an update cannot start
The server was power off for 2 months. Today we power it up and from here the problems…
File “/opt/rockstor/src/rockstor/storageadmin/views/command.py”, line 225, in post
return Response(rockstor_pkg_update_check(subscription=subo))
File “/opt/rockstor/src/rockstor/system/pkg_mgmt.py”, line 293, in rockstor_pkg_update_check
raise e
CommandException: Error running a command. cmd = /usr/bin/yum changelog 2020-Apr-21 rockstor. rc = 1. stdout = [‘Loaded plugins: changelog, fastestmirror’, ‘Loading mirror speeds from cached hostfile’, ‘’]. stderr = [‘’, ‘’, ’ One of the configured repositories failed (Unknown),‘, " and yum doesn’t have enough cached data to continue. At this point the only", ’ safe thing yum can do is fail. There are a few ways to work “fix” this:’, ‘’, ’ 1. Contact the upstream for the repository and get them to fix the problem.‘, ‘’, ’ 2. Reconfigure the baseurl/etc. for the repository, to point to a working’, ’ upstream. This is most often useful if you are using a newer’, ’ distribution release than is supported by the repository (and the’, ’ packages for the previous distribution release still work).‘, ‘’, ’ 3. Run the command with the repository temporarily disabled’, ’ yum --disablerepo= …‘, ‘’, " 4. Disable the repository permanently, so yum won’t use it by default. Yum", ’ will then just ignore the repository until you permanently enable it’, ’ again or use --enablerepo for temporary usage:‘, ‘’, ’ yum-config-manager --disable ’, ’ or’, ’ subscription-manager repos --disable=‘, ‘’, ’ 5. Configure the failing repository to be skipped, if it is unavailable.’, ’ Note that yum will try to contact the repo. when it runs most commands,‘, ’ so will have to try and fail each time (and thus. yum will be be much’, ’ slower). If it is a very temporary problem though, this is often a nice’, ’ compromise:‘, ‘’, ’ yum-config-manager --save --setopt=.skip_if_unavailable=true’, ‘’, ‘Cannot retrieve metalink for repository: epel/x86_64. Please verify its path and try again’, ‘’]
[paste here]
