Unable to create pool on VM
Error to create pool
@Diego Hello again.
Try following the link to our docs indicated in those big red Warning: Disk is unusable messages.
Should explain the short-fall you have re compatibility within your VM host software, or the missing config you will require - assuming it has the required capability/compatibility.
