All pages (dashboard, storage, system, etc.) Are unable to display with the ‘Houston, we have a problem’ error.
Using multiple browsers on same local network as Rockstor NAS attempt to hit any page.
I think it’s the Unifi rock-on … it’s using an insane amount of files (it looks like the process is bouncing but not cleaning up after itself…)
[root@rockstor ~]# lsof | grep unifi | wc -l
103934
File "/opt/rockstor/src/rockstor/storageadmin/views/appliances.py", line 41, in get_queryset
self._update_hostname()
return func(*args, **kwargs)
File "/opt/rockstor/src/rockstor/storageadmin/views/appliances.py", line 48, in _update_hostname
cur_hostname = gethostname()
File "/opt/rockstor/src/rockstor/system/osi.py", line 766, in gethostname
o, e, rc = run_command([HOSTNAMECTL, '--static'])
File "/opt/rockstor/src/rockstor/system/osi.py", line 113, in run_command
'Exception while running command({}): {}'.format(cmd, e))
Exception: Exception while running command(['/usr/bin/hostnamectl', '--static']): [Errno 24] Too many open files
lsof: no pwd entry for UID 911 <-- This line repeats at least 100 times.
106088
[root@rockstor ~]# ps -ef | grep unifi
root 23299 23282 0 Nov19 ? 00:00:00 bash /usr/local/bin/docker-entrypoint.sh unifi
root 23335 23299 0 Nov19 ? 00:00:00 unifi -nodetach -home /usr/lib/jvm/java-8-openjdk-amd64 -classpath /usr/share/java/commons-daemon.jar:/usr/lib/unifi/lib/ace.jar -pidfile /var/run/unifi/unifi.pid -procname unifi -outfile /unifi/log/unifi.out.log -errfile /unifi/log/unifi.err.log -cwd /usr/lib/unifi -Dunifi.datadir=/unifi/data -Dunifi.logdir=/unifi/log -Dunifi.rundir=/var/run/unifi -Xmx1024M -Djava.awt.headless=true -Dfile.encoding=UTF-8 com.ubnt.ace.Launcher start
root 23336 23335 0 Nov19 ? 00:02:17 unifi -nodetach -home /usr/lib/jvm/java-8-openjdk-amd64 -classpath /usr/share/java/commons-daemon.jar:/usr/lib/unifi/lib/ace.jar -pidfile /var/run/unifi/unifi.pid -procname unifi -outfile /unifi/log/unifi.out.log -errfile /unifi/log/unifi.err.log -cwd /usr/lib/unifi -Dunifi.datadir=/unifi/data -Dunifi.logdir=/unifi/log -Dunifi.rundir=/var/run/unifi -Xmx1024M -Djava.awt.headless=true -Dfile.encoding=UTF-8 com.ubnt.ace.Launcher start
root 23867 22659 0 11:47 pts/0 00:00:00 grep --color=auto unifi
root 25255 23336 0 Nov19 ? 00:06:31 /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java -Xms1024M -Xmx1024M -XX:ErrorFile=/usr/lib/unifi/logs/hs_err_pid%p.log -Dapple.awt.UIElement=true -jar /usr/lib/unifi/lib/ace.jar start
root 26159 25255 0 Nov19 ? 00:15:18 bin/mongod --dbpath /usr/lib/unifi/data/db --port 27117 --unixSocketPrefix /usr/lib/unifi/run --logappend --logpath /usr/lib/unifi/logs/mongod.log --nohttpinterface --bind_ip 127.0.0.1
