OK now Iām a little bit confused.
I once more checked the logs and all my 6 drives are identified correctly and the link speed is also set to the correct value.
The messages/failiures I get are for ata 7&8 which are not present on my mainboard. I only have connectors for sata 1-6-
So I wonder why I get these messages
Apr 14 09:24:26 localhost kernel: ata7: SATA max UDMA/133 cmd 0xf090 ctl 0xf080 bmdma 0xf050 irq 19
Apr 14 09:24:26 localhost kernel: ata8: SATA max UDMA/133 cmd 0xf070 ctl 0xf060 bmdma 0xf058 irq 19
Apr 14 09:24:42 localhost kernel: ata7: link is slow to respond, please be patient (ready=-19)
Apr 14 09:24:42 localhost kernel: ata8: link is slow to respond, please be patient (ready=-19)
Apr 14 09:24:46 localhost kernel: ata8: SRST failed (errno=-16)
Apr 14 09:24:46 localhost kernel: ata7: SRST failed (errno=-16)
on the other hand ata5&6 are connected with 3.0 Gbps
Apr 14 09:24:37 localhost kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Apr 14 09:24:37 localhost kernel: ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
but are limited later on also to 1.5 Gbps like ata7&8
Apr 14 09:25:22 localhost kernel: ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Apr 14 09:25:22 localhost kernel: ata6: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
perhaps ata7 & 8 are reserved for eSATA connectors but in the manual of my mainbord it is stated, that they should not be present in my version of the MSI P67A-GD53 and only available in P67A-GD65.
If I take a look into the disk info (Rockstor WebUI), I can exactly follow the results:
The disks connected to sata 5&6 are limited to 1,5 Gbps.
Disks connected to sata 1-4 work with the expected speed of 3 or 6 Gbps.
After I changed sata connection of some drives Rock-Ons like owncloud but also other will not start again and reinstallation failed.
I really donāt know if it was a good idea to upgrade to Rockstore 5 on SuSE Leap
Following messages in rockstor.log (rock-on owncloud official cannot be installes again)
[14/Apr/2021 21:01:53] INFO [storageadmin.tasks:55] Now executing Huey task [install], id: 36dffe14-4614-4c67-9aba-6458f18f92f6.
[14/Apr/2021 21:01:53] ERROR [system.osi:199] non-zero code(1) returned by command: ['/usr/bin/docker', 'stop', 'owncloud-official']. output: [''] error: ['Error response from daemon: No such container: owncloud-official', '']
[14/Apr/2021 21:01:53] ERROR [system.osi:199] non-zero code(1) returned by command: ['/usr/bin/docker', 'rm', 'owncloud-official']. output: [''] error: ['Error: No such container: owncloud-official', '']
[14/Apr/2021 21:01:55] ERROR [system.osi:199] non-zero code(127) returned by command: ['/usr/bin/docker', 'run', '-d', '--restart=unless-stopped', '--name', 'owncloud-official', '-v', '/mnt2/owncloud:/var/www/html', '-v', '/etc/localtime:/etc/localtime:ro', '-p', '8080:80/tcp', '-p', '8080:80/udp', 'owncloud:latest']. output: [''] error: ['docker: Error response from daemon: stat /mnt2/ROCK-ONS/btrfs/subvolumes/bf85d96eb6bc3f36e633530611881ca3a8ee8da7bd107aa78341b4b3ae80a7ec: no such file or directory.', "See 'docker run --help'.", '']
[14/Apr/2021 21:01:55] ERROR [storageadmin.views.rockon_helpers:207] Error running a command. cmd = /usr/bin/docker run -d --restart=unless-stopped --name owncloud-official -v /mnt2/owncloud:/var/www/html -v /etc/localtime:/etc/localtime:ro -p 8080:80/tcp -p 8080:80/udp owncloud:latest. rc = 127. stdout = ['']. stderr = ['docker: Error response from daemon: stat /mnt2/ROCK-ONS/btrfs/subvolumes/bf85d96eb6bc3f36e633530611881ca3a8ee8da7bd107aa78341b4b3ae80a7ec: no such file or directory.', "See 'docker run --help'.", '']
File "/opt/rockstor/src/rockstor/storageadmin/views/rockon_helpers.py", line 204, in install
globals().get("{}_install".format(rockon.name.lower()), generic_install)(rockon)
File "/opt/rockstor/src/rockstor/storageadmin/views/rockon_helpers.py", line 390, in generic_install
run_command(cmd, log=True)
File "/opt/rockstor/src/rockstor/system/osi.py", line 201, in run_command
CommandException: Error running a command. cmd = /usr/bin/docker run -d --restart=unless-stopped --name owncloud-official -v /mnt2/owncloud:/var/www/html -v /etc/localtime:/etc/localtime:ro -p 8080:80/tcp -p 8080:80/udp owncloud:latest. rc = 127. stdout = ['']. stderr = ['docker: Error response from daemon: stat /mnt2/ROCK-ONS/btrfs/subvolumes/bf85d96eb6bc3f36e633530611881ca3a8ee8da7bd107aa78341b4b3ae80a7ec: no such file or directory.', "See 'docker run --help'.", '']
[14/Apr/2021 21:01:55] INFO [storageadmin.tasks:63] Task [install] completed OK
