Turns out the spare drive has a bad sector or two. Not enough for SMART to say it is bad but it is causing BTRFS to have a cow.
It is not a big deal as it is an older drive and I have a new 4Tb on order. Im just wondering what the procedure would be to replace it and have rockstor/BTRFS migrate the data.
To help folks in addressing this thread in isolation could you copy in the info for the pool concerned. I.e. is it the system drive or a member in a multi drive pool for example. I know you have other forum threads that likely have this info but no harm in having a repeat hear and helps folks chip in who are more fly by readers of the forum. The output of the following commands should help to inform folks of your btrfs setup:
btrfs fi show
and
btrfs fi usage /mnt2/pool-name-here
In short if the pool is a multi dev one and itâs dev count including this suspect device is at the minimum of itâs btrfs raid profile then you can, via Rockstor Web-UI either:
Add a new member, then when the resulting balance is complete remove the suspect member.
Reduce the raid level to a point where the suspect device can be removed without resorting to a degraded mount option.
In both cases there will be stress applied to the âsuspectâ device. A further command line only option is to use the as yet unsupported btrfs option of replace. See the following issue we have open for some notes on this btrfs capability:
As indicated in that issue we do already have a Web-UI placeholder for this. Iâm not entirely certain what the UI will make of this going on underneath it but once itâs completed it should self correct. But it will likely be a little confused while the command line replace action is in-progress.
But in a multi dev pool scenario the result is a transparent transition of the outgoing drives date to the rest of the pool, within the remit of the btrfs raid level at the time. The pools will also remain accessible during this transition, all-be-it at reduces performance as it will likely be very busy fulfilling the data migration/re-raid operations.
I was just looking for a general overview and this answered my question.
The reason I just needed the general overview is the bad drive is the one I am using for testing transfer speeds and only contains copies of data that exist elsewhere. I also set up a container running BackupPC to backup my non-cloud based systems and Im using that drive as the storage for that test.
So I can loose it and there is no issue. I just thought it would be a good chance to work with and test the replacement process in the UI if there was one.
In this case it is a single disk pool.
nas:~ # btrfs fi show
Label: 'plat-cloud-backup' uuid: 156482f2-05b9-46c7-8b0e-98cd72370e52
Total devices 1 FS bytes used 613.12GiB
devid 1 size 2.73TiB used 616.06GiB path /dev/sdd
nas:~ # btrfs fi usage /mnt2/plat-cloud-backup/
Overall:
Device size: 2.73TiB
Device allocated: 616.06GiB
Device unallocated: 2.13TiB
Device missing: 0.00B
Used: 615.06GiB
Free (estimated): 2.13TiB (min: 1.06TiB)
Data ratio: 1.00
Metadata ratio: 2.00
Global reserve: 512.00MiB (used: 0.00B)
Data,single: Size:612.00GiB, Used:611.19GiB
/dev/sdd 612.00GiB
Metadata,DUP: Size:2.00GiB, Used:1.93GiB
/dev/sdd 4.00GiB
System,DUP: Size:32.00MiB, Used:112.00KiB
/dev/sdd 64.00MiB
Unallocated:
/dev/sdd 2.13TiB
OK, so especially given the data is not critical, your could simply add a disk to this pool, maintaining itâs single btrfs raid status (dup metadata) and then once that is finished and you have a 2 disk single btrfs raid level pool, remove from that pool the suspect device. There by, some what long windedly, maintain the pool arrangement / configuration yet transitioning itâs substrate: backing device in this case . And this would also give you a feel for how Rockstor represents the interim stages. Slightly risky as you have a known failing disk and are not simultaneously moving to a redundant raid scenario, but still, doable in the context of throw away data. And hopefully there will be no new occurrences of bad sectors that might otherwise kill a pool in a non redundant raid arrangement. Options are necessarily reduced when working at the lowest dev count limit so always best to attempt to achieve at least a +1 dev count above the btrfs raid lower dev count limit as you then circumvent the need to address both redundancy and raid level. But a single disk can only be (non degraded) a btrfs single raid level anyway.
Yes, âerrorsâ can cover a variety of situations; some will be blockers and other not. But the balance enacted on adding a device is not critical to itâs addition to the pool, in a add then remove scenario. Always tricky if there are errors given the can affect the pool in so many ways.
Thanks for sharing your findings and your eventual work around, much appreciated and can serve as a guide for others facing similar dead ends re options within the Web-UI.
Definitely. Fancy putting in a pull request? Unfortunately itâs a non trivial feature that requires extensive testing across all the various drive / btrfs raid level permutations so will take quite the attention to get sorted. However from your report it looks like the the Web-UI ended up sorting itself out in the end post the replace command line intervention. So thatâs good to know.
Glad youâve got this sorted and thanks again for the feedback. We are on shifting sands with all our dependencies and btrfs is constantly being updated and poorly pools are very difficult to predict re capabilities. The balance enacted post Web-UI drive addition is non critical. If it fails it will generally mean the data is just not spread out evenly. But the âinternalâ balance enacted on a drive removal is quite a different animal, it is auto initiated by the filesystem itself (with add drive we just run a balance afterwards as that is what most folks expect). And this integrated drive removal balance also doesnât show up in btrfs balance status commands. We infer itâs function to try and present it similarly within the Web-UI.
Re re-size required after replace, yes thatâs a regular question on the btrfs mailing list. Known behaviour currently and when we do implement a replace function we should either just do this or do a tick to ask for it or something.
@phillxnet
I just opened up a bug report on the git repo. Seems when the drive is replaced and the errors cleared, it does not clear the web interface DEV Error. So it looks like the NAS still has a bad pool after it is fixed.
As to putting in a pull request, Im not a programmer. I work as a Sr Cloud Infrastructure Engineer. While I can program in a small handful of languages, it is just hack coding to get the job done. lol
Note: Part of the reason I am posting stuff like this is to document it so others who run into the issue can find a quicker solution to the problem. Just helping with the documentation so to speak.
Excellent and much appreciated. Iâve responded to the issue on GitHub. And itâs hopefully influenced the creation of a couple of others. All good stuff and thanks for your diligence in all of this, the docs (like all other bits) are constantly in need of attention but we have had quite the community contribution there so thatâs fantastic. But as always, always much to do.
Bit by bit and thanks again for sharing your findings work arounds.
I have yet to successfully replace a âDEADâ drive in either a Raid-0 or Raid-10 configuration. My only resort has been to reinstall Rockstor, import the pools I want to keep then recreate the bad pool with the replaced drive. It works, but takes hours to copy from backups.
Would like to see some work on this!
And thanks for the command line method, I may try that next time.
