Xenserver pool only works with nfs Admin Host. i can not move vm’s freely between xenservers. if i remove Admin Host ip address no server works
why is this getting flagged
Hi @Allen_Ford
Probably because you’re asking about Xenserver, and this is a forum for Rockstor. There’s nothing in your question that seems to relate to Rockstor. If it is about Rockstor, you might want to explain how it relates to Rockstor.
well it was directly related iusing rockstor as the nfs sever… xenserver is just the client
and the Admin Host setting is in Rockstor not xenserver.
my main question is how to get the all nfs clients to all be able to edit/write to the the nfs export instead of only the ip in the admin host setting.
i fixed this issue by actually changing the write permissions in the ROCKSTOR. by defualt the permissions only allow write access to the admin host. so the issue was related to rockstor, and my post should of requested more details rather then to disable and mark as spam lol
That makes the issue just as related to the electricity company, since your server runs in their electricity. A strange way to look at things, and as far as I can see nobody should have to try to figure out what exactly your situation or question is. It’s up to the person who wants information or help (you, in this case) to be as clear and complete as possible.
Your question was not even a question, just a vague statement - so yeah, that’s probably what got it flagged.
