I’m busy migrating some Thecus NAS devices to RockStor. However, I’m unable to link the 2 appliances I have built because they both have the same unique Appliance ID. How could this have happened? The model numbers of each hardware device are different, with different host names and different IPs. They were both installed from the same USB key. They both run from an internal SATA SSD device.
Install latest stable build … 3.9.1-0
File "/opt/rockstor/src/rockstor/storageadmin/views/appliances.py", line 110, in post
appliance.save()
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/base.py", line 734, in save
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/base.py", line 762, in save_base
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/base.py", line 846, in _save_table
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/base.py", line 885, in _do_insert
using=using, raw=raw)
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/query.py", line 920, in _insert
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/compiler.py", line 974, in execute_sql
cursor.execute(sql, params)
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/backends/utils.py", line 64, in execute
File "/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/utils.py", line 98, in __exit__
IntegrityError: duplicate key value violates unique constraint "storageadmin_appliance_uuid_key"
DETAIL: Key (uuid)=(REMOVED) already exists.
