Error during repo refresh
When trying to update or refresh through the System Shell, I get the following error
Repository 'Rockstor-Stable' is invalid.
[Rockstor-Stable|http://<myapplianceid>@updates.rockstor.com:8999/rockstor-stable/leap/15.4?credentials=/e
tc/zypp/credentials.d/Rockstor-Stable&auth=basic] Valid metadata not found at specified URL
History:
[Rockstor-Stable|http://<myapplianceid>@updates.rockstor.com:8999/rockstor-stable /leap/15.4?credentials
=/etc/zypp/credentials.d/Rockstor-Stable&auth=basic] Repository type can't be determined.
Please check if the URIs defined for this repository are pointing to a valid repository.
Skipping repository 'Rockstor-Stable' because of the above error.
Running either of the following commands
zypper up
and
zypper refresh
48%20PM
Troubleshooting steps
I’ve only tried removing the repo and switching from stable updates to testing updates, and then back again. Same error occurs
Also censored applianceID as I’m not really sure if that’s even sensitive or not
@QuiveryNut Welcome to the Rockstor community forum.
This one is easy. We have not yet released a Stable rpm (repository) for Leap 15.4, but we are getting there. As of this post we are on our Release Candidate 3 (RC3) in the testing channel, which is also included in our most recent downloadable installers:
And the repo will just be skipped as a result, at least untill it actualy exists, as indicated by the:
We have the following GitHub milestone for our next stable release:
@phillxnet that was a huge help, thank you!
