Failed to start samba after update
Samba is not starting after update.
  1. I tried to update Rockstor via web-ui
  2. I turned off the computer while the update was installing by error.
  3. I deleted the malfunctioning kernel and updated via the shell (from the computer monitor)
  4. Now samba fails to start
Traceback (most recent call last): File "/opt/rockstor/src/rockstor/smart_manager/views/samba_service.py", line 113, in post systemctl('nmb', command) File "/opt/rockstor/src/rockstor/system/services.py", line 64, in systemctl return run_command([SYSTEMCTL_BIN, switch, service_name]) File "/opt/rockstor/src/rockstor/system/osi.py", line 121, in run_command raise CommandException(cmd, out, err, rc) CommandException: Error running a command. cmd = /usr/bin/systemctl start nmb. rc = 1. stdout = ['']. stderr = ['Job for nmb.service failed because the control process exited with error code. See "systemctl status nmb.service" and "journalctl -xe" for details.', '']
I’m sorry but i’m a noob with this. I already looked at other topics but it seems i’m not understanding a lot of things because i don’t know any command on linux. I tried to enforce selinux and to disable it with no success…
after doing systemctl status nmb:
Hi @LIBR4life , and welcome to the community!
Yes, I believe your problem comes from that, especially given the error you see when trying to start the Samba service. From your screenshot (thanks a lot for including it):
version 'SAMBA_4.4.4' not found
…we can see that the samba package does not appear to be installed. Given the computer was turned off mid-updates, this is not that surprising as yum doesn’t really seem to like that.
I would thus run sudo yum update from the terminal to process any remaining updates and make sure they all install successfully. If Samba is not one of these packages to be updated/re-installed, you can have a look at: yum info samba and see what version you have. It is possible you are in the same situation as in the post below:
Try the sudo yum update first and see how it goes. Then have a look at the status of your current samba install yum info samba. We should be able to have a better idea from the outputs of these two commands.
Hope this helps,
Hello, thanks for the fast response. Here’s the output of sudo yum update and yum info samba:
Thanks for the additional information.
It appears the latest samba version did install correclty, yet nmb seems to still look for Samba 4.4.4. As I result, I would first restart your machine to reload everythin, as it always prove useful after so many updates.
I would then guide you towards the excellent troubleshooting that @Haioken did in the thread I linked above (and pasted below):
In particular, it started with:
journalctl -u nmb.service
systemctl status smb.service
journalctl -u smb.service
Make sure to copy + paste the outputs for both of these (the system shell we use, Shellinabox, let’s you use Ctrl + C to copy) so that we can see all details.
These should help a little more, hopefully.
Thank you. These are the outputs:
 [root@nas_server ~]# systemctl status nmb.service
    â—Ź nmb.service - Samba NMB Daemon
       Loaded: loaded (/usr/lib/systemd/system/nmb.service; enabled; vendor preset: disabled)
       Active: failed (Result: exit-code) since Wed 2020-03-18 14:47:07 CET; 43s ago
         Docs: man:nmbd(8)
               man:samba(7)
               man:smb.conf(5)
      Process: 2681 ExecStart=/usr/sbin/nmbd --foreground --no-process-group $NMBDOPTIONS (code=exited, status=1/FAILURE)
     Main PID: 2681 (code=exited, status=1/FAILURE)
Mar 18 14:47:07 nas_server systemd[1]: Starting Samba NMB Daemon...
Mar 18 14:47:07 nas_server nmbd[2681]: /usr/sbin/nmbd: /usr/lib64/samba/libreplace-samba4.so: version `SAMBA_4.4.4' not found (required by /lib64/libwbclient.so.0)
Mar 18 14:47:07 nas_server nmbd[2681]: /usr/sbin/nmbd: /usr/lib64/samba/libwinbind-client-samba4.so: version `SAMBA_4.4.4' not found (required by /lib64/libwbclient.so.0)
Mar 18 14:47:07 nas_server systemd[1]: nmb.service: main process exited, code=exited, status=1/FAILURE
Mar 18 14:47:07 nas_server systemd[1]: Failed to start Samba NMB Daemon.
Mar 18 14:47:07 nas_server systemd[1]: Unit nmb.service entered failed state.
Mar 18 14:47:07 nas_server systemd[1]: nmb.service failed.
[root@nas_server ~]# journalctl -u nmb.service
-- Logs begin at Wed 2020-03-18 14:45:28 CET, end at Wed 2020-03-18 14:48:24 CET. --
[root@nas_server ~]# systemctl status smb.service
â—Ź smb.service - Samba SMB Daemon
   Loaded: loaded (/etc/systemd/system/smb.service; enabled; vendor preset: disabled)
   Active: inactive (dead)
[root@nas_server ~]# journalctl -u smb.service
-- No entries --
OK, so if we look at the following…
/usr/sbin/nmbd: /usr/lib64/samba/libwinbind-client-samba4.so: version SAMBA_4.4.4’ not found (required by /lib64/libwbclient.so.0)`
…we can see that you’re probably in the same case as in the thread I linked and that we’re following: an issue with the installation of libwbclient as the latter seems to have stayed on v4.4.4 rather than following the update samba version 4.9.1 (was 4.4.4). These two packages are highly interconnected so I’m not surprised to see error if one’s version doesn’t match the other.
You should first check your installed versions:
yum info samba
yum info libwbclient
On my machine I have:
[root@rockdev ~]# yum info samba
 * base: mirror.nodesdirect.com
 * epel: fedora-epel.mirrors.tds.net
 * extras: mirror.nodesdirect.com
 * updates: mirror.nodesdirect.com
Installed Packages
Arch        : x86_64
Version     : 4.9.1
Release     : 10.el7_7
Repo        : installed
From repo   : updates
Summary     : Server and Client software to interoperate with Windows machines
URL         : http://www.samba.org/
License     : GPLv3+ and LGPLv3+
Description : Samba is the standard Windows interoperability suite of programs for Linux and
            : Unix.
[root@rockdev ~]#
[root@rockdev ~]# yum info libwbclient
Installed Packages
Arch        : x86_64
Version     : 4.9.1
Release     : 10.el7_7
Repo        : installed
From repo   : updates
Summary     : The winbind client library
Description : The libwbclient package contains the winbind client library from the Samba
            : suite.
Available Packages
Arch        : i686
Version     : 4.9.1
Release     : 10.el7_7
Repo        : updates/x86_64
            : suite.
Now, I suspect your libwbclient remained at v4.4.4.
If that is the case, you could try forcing its install at indicated by @Haioken:
yum reinstall libwbclient -y && systemctl restart nmb.service
These are the outputs from the first two commands:
[root@nas_server ~]# yum info samba
 * base: mirrors.prometeus.net
 * epel: mirror.euserv.net
 * extras: mirrors.prometeus.net
 * updates: mirrors.prometeus.net
Installed Packages
Arch        : x86_64
Version     : 4.9.1
Release     : 10.el7_7
Repo        : installed
            : Unix.
[root@nas_server ~]# yum info libwbclient
Installed Packages
Arch        : x86_64
Version     : 4.4.4
Release     : 14.el7_3
Repo        : installed
From repo   : anaconda
            : suite.
Arch        : x86_64
Version     : 4.9.1
Release     : 10.el7_7
Repo        : installed
            : suite.
Available Packages
Arch        : i686
Version     : 4.9.1
Release     : 10.el7_7
            : suite.
Then i run the last command, but it didn’t resolve the problem. I can’t write the output because there are too many characters. Don’t you think that i only need to delete the old libwbclient? Because they are both installed (the old and the new one).
That’s only a part of the output:
[root@nas_server ~]# yum reinstall libwbclient -y && systemctl restart nmb.service
 * epel: mirror.nextlayer.at
Rockstor-Testing        | 2.9 kB  00:00:00
rockstor        | 2.9 kB  00:00:00
Resolving Dependencies
There are unfinished transactions remaining. You might consider running yum-complete-transaction, or "yum-complete-transaction --cleanup-only" and "yu
m history redo last", first to finish them. If those don't work you'll have to try removing/installing packages by hand (maybe package-cleanup can hel
p).
The program yum-complete-transaction is found in the yum-utils package.
--> Running transaction check
---> Package libwbclient.x86_64 0:4.4.4-14.el7_3 will be updated
--> Processing Dependency: libwbclient = 4.4.4-14.el7_3 for package: samba-common-tools-4.4.4-14.el7_3.x86_64
--> Processing Dependency: libwbclient = 4.4.4-14.el7_3 for package: samba-winbind-modules-4.4.4-14.el7_3.x86_64
--> Processing Dependency: libwbclient = 4.4.4-14.el7_3 for package: samba-common-libs-4.4.4-14.el7_3.x86_64
--> Processing Dependency: libwbclient = 4.4.4-14.el7_3 for package: samba-libs-4.4.4-14.el7_3.x86_64
--> Processing Dependency: libwbclient = 4.4.4-14.el7_3 for package: samba-client-libs-4.4.4-14.el7_3.x86_64
--> Processing Dependency: libwbclient = 4.4.4-14.el7_3 for package: samba-winbind-krb5-locator-4.4.4-14.el7_3.x86_64
--> Processing Dependency: libwinbind-client-samba4.so(SAMBA_4.4.4)(64bit) for package: samba-winbind-modules-4.4.4-14.el7_3.x86_64
---> Package libwbclient.x86_64 0:4.9.1-10.el7_7 will be an update
---> Package libwbclient.x86_64 0:4.9.1-10.el7_7 will be erased
--> Finished Dependency Resolution
Error: Package: samba-winbind-krb5-locator-4.4.4-14.el7_3.x86_64 (@anaconda/3)
           Requires: libwbclient = 4.4.4-14.el7_3
           Removing: libwbclient-4.4.4-14.el7_3.x86_64 (@anaconda/3)
           Updated By: libwbclient-4.9.1-10.el7_7.x86_64 (updates)
               libwbclient = 4.9.1-10.el7_7
           Available: libwbclient-4.9.1-6.el7.i686 (base)
               libwbclient = 4.9.1-6.el7
Error: Package: samba-common-tools-4.4.4-14.el7_3.x86_64 (@anaconda/3)
Error: Package: samba-winbind-modules-4.4.4-14.el7_3.x86_64 (@anaconda/3)
Error: Package: samba-common-libs-4.4.4-14.el7_3.x86_64 (@anaconda/3)
Error: Package: samba-libs-4.4.4-14.el7_3.x86_64 (@anaconda/3)
Error: Package: samba-client-libs-4.4.4-14.el7_3.x86_64 (@anaconda/3)
           Requires: libwinbind-client-samba4.so(SAMBA_4.4.4)(64bit)
              ~libwinbind-client-samba4.so(SAMBA_4.9.1)(64bit)
 You could try using --skip-broken to work around the problem
** Found 319 pre-existing rpmdb problem(s), 'yum check' output follows:
That’s rather unexpected… I didn’t that was possible. In this case yes, uninstalling them and then reinstalling them might help, but I’m not sure how yum will deal with that. You can always try yum remove libwbclient and see what is listed as package(s) to remove… hopefully both will be listed for removal so that you can re-install it.
I managed to remove the two libwbclients and reinstall the new one but it says “failed to restart nmb.service: unit not found”. (I’m sorry but i can only do a photo with my phone)
What should I do now?
Mmm… interesting… I wasn’t expecting that one either. My first thought is to re-install samba as nmb.service is provided by the samba package.
You can try the following commands:
yum remove samba
systemctl status smb nmb
yum install samba
And paste the output here. On my machine, for reference, I have:
[root@rockdev ~]# yum remove samba
---> Package samba.x86_64 0:4.9.1-10.el7_7 will be erased
Dependencies Resolved
 Package                                                       Arch                                                           Version        Repository                                                        Size
Removing:
 samba                                                         x86_64                                                         4.9.1-10.el7_7                                                            @updates                                                         1.9 M
Transaction Summary
Remove  1 Package
Installed size: 1.9 M
Is this ok [y/N]: y
Downloading packages:
Running transaction test
Transaction test succeeded
Running transaction
  Erasing    : samba-4.9.1-10.el7_7.x86_64        1/1
  Verifying  : samba-4.9.1-10.el7_7.x86_64        1/1
Removed:
Complete!
[root@rockdev ~]# systemctl status smb nmb
Unit smb.service could not be found.
Unit nmb.service could not be found.
[root@rockdev ~]#
[root@rockdev ~]#
[root@rockdev ~]# yum install samba
---> Package samba.x86_64 0:4.9.1-10.el7_7 will be installed
Installing:
 samba                                                          x86_64                                                          4.9.1-10.el7_7                                                          updates                                                          685 k
Transaction Summary
Install  1 Package
Total download size: 685 k
Is this ok [y/d/N]: y
samba-4.9.1-10.el7_7.x86_64.rpm        | 685 kB  00:00:00
Running transaction
  Installing : samba-4.9.1-10.el7_7.x86_64        1/1
Installed:
Complete!
[root@rockdev ~]#
   Loaded: loaded (/usr/lib/systemd/system/smb.service; disabled; vendor preset: disabled)
     Docs: man:smbd(8)
           man:samba(7)
           man:smb.conf(5)
   Loaded: loaded (/usr/lib/systemd/system/nmb.service; disabled; vendor preset: disabled)
     Docs: man:nmbd(8)
           man:samba(7)
           man:smb.conf(5)
Hopefully we’re getting closer now.
I think i have resolved the samba issue but now another problem comes… I can’t access the web ui anymore…
It looks like your Rockstor install was damaged… probably while removing samba. I’m worried your repos are affected as well, but if you do see Rockstor-Testing in the output of yum repolist, you can try to yum install rockstor.
Hi, I solved everything with these commands and now works like new! Thank you for your support!
Thanks for letting us know!
You’re probably fine now with all the updates, but let us know if you notice anything odd.
Regarding Samba, make sure to configure the service using the little wrench icon next to Samba in the Services page as we had some silent oddity there. It has now been fixed in the Stable channel, but in the Testing channel, you would need to make sure you do configure it first and then toggle it ON.
Hope everything will go smoothly from now on,
Cheers!
