Have we considering using a script to force a cleanup in postgres in storageadmin for rockons, dcontainer, dcontainerenv, dport, dimage, etc with a big warning? This would be very beneficial for anyone with a container stuck removing or other strange scenario.
If someone manually removes the container outside of rockstor, this would be needed, otherwise the UI acts as if it’s still installing or removing the rockon.
For testing custom rockons, this is also beneficial
using a script in /opt/rockstor/bin may be the best path also
Ideally, a flag could toggle an extra option to do this in the UI and perhaps a script, like the debug mode, could trigger it?
Have you had a look at the currently undocumented:
It was added to ‘force’ remove ‘problematic’ named rock-ons. One at a time, and might be a good place to start with extending such ‘emergency’ maintenance tools re rock-ons.
