S.M.A.R.T. details won’t load when refreshed for my Western Digital: WDC WD10EADS-00M, I have 2 others drives from Toshiba which the smart works on. WDC is also connected on the same controllers as the 2 others.
Go to Storage → Disks → click on the name, in my case, “sdd” → then your in S.M.A.R.T details for sdd → push button refresh.
File "/opt/rockstor/src/rockstor/storageadmin/views/disk_smart.py", line 123, in post
return self._info(disk)
return func(*args, **kwargs)
File "/opt/rockstor/src/rockstor/storageadmin/views/disk_smart.py", line 90, in _info
state=l[1], etype=l[2], details=l[3]).save()
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/base.py", line 545, in save
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/base.py", line 573, in save_base
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/base.py", line 654, in _save_table
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/base.py", line 687, in _do_insert
using=using, raw=raw)
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/manager.py", line 232, in _insert
return insert_query(self.model, objs, fields, **kwargs)
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/query.py", line 1514, in insert_query
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/sql/compiler.py", line 903, in execute_sql
cursor.execute(sql, params)
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/backends/util.py", line 53, in execute
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/utils.py", line 99, in __exit__
IntegrityError: null value in column "details" violates not-null constraint
DETAIL: Failing row contains (4, 6, 973, 8240, active or idle., Command ABoRTed, null).
@kziegler Welcome to the Rockstor community and thanks for reporting this. We haven’t had one of these for a while now; it looks very much like a parsing error / bug when Rockstor tries to format the error log returned from the drive so that it might be presented in the Web-UI.
In order to get this sorted we will have to have an exact copy of the output received from the smartctl commands that are run in the background on the problem drive when the refresh button is pressed. If you could execute the following commands as root via ssh and return the resulting smart-issue-report.tar.gz file it would be a great help to getting this sorted:
Which should copy the file of interest to the current directory of the client machine.
Please email the smart-issue-report.tar.gz file as an attachment to support@rockstor.com with a note indicating it relates to this forum thread and the following referenced issue.
Thanks for helping to get this bug sorted, it may take some time but I have opened an issue to keep track of progress:
@kziegler My appologies, I’m afraid I dropped the ball on this one, sort of.
I have just realised that a duplicate report has now been fixed so as of testing channel release 3.8.15-3 your reported issue should be sorted only against the now duplicate marked:
Sorry for the slip-up and lack of attribution in the dev channel updates on my part here.
