Hey folks,
I’ve been lurking for a while and testing Rockstor in a VM for quite a bit. I am considering moving from TrueNAS Scale with a replication server to Rockstor for my home storage environment. Before I do so, just wanted to see if the project was going to have a stable release soon and if I should roll out with 15.6 or tumbleweed? The project looks good so far BTW and thanks!
@mtgranito Welcome to the Rockstor community forum.
Yes, our current downloadable installers have pre-installed 5.0.15-0 which is at Stable Release Candidate 10:
15.6, as per the recommendation on the Downloads page. Tumbleweed is hard to track as it changes so often and we offer it for more advanced users and to see where we are heading as it were. I.e. folks can, via the Tumbleweed based installer, assess what we need to accommodate and how we are doing for future versions as it were.
Also note that subscribing to Stable, on an openSUSE Leap 15.6 based installer, even thought we are pre 5.1.. Stable release, is find. It just means your system will be held at it’s current ‘rockstor’ rpm version until we do publish our next Stable rpm. We got folks onto late testing (Release Candidate) in our more recent installers given this last testing phase has been a rather long one. This way we ensured new installs where based on near modern Stable (RC), rather than older Stable, as they were. Plus we had a lot of work to do re updating and testing the installers also. But the vast majority of this work has now been finished.
That does indeed! Is there a published roadmap anywhere that is public? I’d be curious to see is next for project. Again, thank you!
@mtgranito Re:
We use mainly GitHub Milestones, and have recently added a new one as the focus of our next testing phase:
Other than that we try to respond to queries, request, & bug reports; and have these guide priorities if possible within the current Milestone. Resources, as almost always in Open Source, are limited: so we have to take little steps. But sometimes the needed steps are just big: that was the case with this closing testing phase - hence the delay since releasing our last Stable rpm. Plus, as we are a community project, what gets done is what folks tend to contribute. While the maintainers balance this with more over-arching needs re updates etc. Essentially we are modernising our code base and reducing our dependencies before branching out to more interesting facilities. But all in good time.
Hope that helps, at least regarding our near term goals.
Hi @mtgranito
I have Rockstor running on dedicated hardware for home usage for 1,5 years now and I am more than happy with it.
About 4 months ago I made a fresh installation with the latest installer (Rockstor 5.x built on Leap 15.6), immediately updated to the latest version in the development branch and then activated the stable licence.
I am running rockstor without any issues and can definitely recommend it for home use
Best regards
Simon
I have been running Rockstor for many years as well. I use it in the most elementary way as simply a SAMBA NAS without replication. The 2 current setups are simply Dual Raid-10 (14 drive) and Single Raid-0 (5 drive) boxes. Another setup is being built to mirror the first setup with a larger Raid-10 configuration and the older 5 drive setup will be used as test machine.
Version 4.01 worked for me a long time but 15.6 has really got my setups super stable and slightly faster.
PM me if you want a free Rockstor Case badge or purchase one on EBay. The shipping has been fixed so it will work world-wide! (I think)
Thanks for the feedback! My current setup has a ton of horsepower (Ryzen 7 5700x with 128GB of ram, 60+ TB of storage) running Truenas Scale currently. While ZFS has ARC, does BTRFS use ram in a similar way? Also, besides replication to a second appliance is there a way I can mount an external USB drive to NAS and have it perform a standalone backup to it? Bonus points if it did versioning and deduplication/compressision!
Ummm, I don’t like replication and history keeping myself, but I recall there are services that can probably do what you want either natively or through a RockOn install.
Personally, I’m a single person on my personal network with no external shares/access at all. I simply have hundreds (over 1000 maybe?) DVD’s, BlueRay’s, audio CD’s, and personal video’s to manage. This being the case, I use a 10G fiber optic network and use copy on change software to backup from my NAS to my backup NAS. I can do a 17TB backup in about one day and then just update the backup as necessary. While the backup is running at about 490MB/Sec, the 10G LAN has no trouble supporting all my other needs.
I think if you search the forum and Wiki, you can find backup stuff using several different methods.
Have fun and good luck!
Regarding the “local” replication:
There is no such built-in way in Rockstor, but you can try one of the following:
- Have a 2nd rockstor applience to which your USB drive is attached and use the Rockstor replication
(e.g. even a RaspberryPi 3+ / 4 will do the job, or you could also think about running the 2nd applience as a virtual machine) - There are also Rock-ons for backup purpose including deduplication & compression (have a look at Duplicati 2.0)
- Use any other generic linux backup tool by installing and configuring it in the OS of your Rockstor machine. My favorite tools are:
- BorgBackup (deduplication & compression), or the great “wrapper” Borgmatic if you prefer to work with config files
- btrbk utilises btrfs send & receive to “clone” btrfs subvolumes to an external drive including deduplication (but no compression)
I use btrbk to “clone” my relevant BTRFS subvolumes to an external (USB 3.5" HDD-Bay) for offline & remote backups (at my parents home) and can recommend this approach if you are willing to set btrbk up by yourself.
Alternatively, the probably easier approach is to simply set up a 2nd applience with a Raspbery Pi and use the Rockstor replication feature.
Cheer Simon
