I think that rockstor must have a tor proxy server rock-on. And you can use it on your home pc.
hi ,
it would be nice to see zabbix 3.x as rockon
Couchpotato and Sonarr rock-ons are ready With pull request.
Sabnzb plugin ready and working. @suman : Have added pullrequest, git-user tronder88
I will clean up script a little in the future and add a new pullrequest, but scripts do work as intended.
@phillxnet I noticed the interest in Gitlab in this conversation. Iāve got gogs running as a Rock-on using the official Docker image and separate shares for gogs configuration and the git repository. Gogs is good deal more lightweight than gitlab, yet feature-rich enough for most of us. Iām wondering if there would be any interest in it.
@pdenhaan Thatās great news. If you are game Iām pretty sure a pull request to the rockstor-registry would be more than welcome. Well done.
From my perspective Iām a little tied into gitlab at the moment but yes it is rather on the heavy as in massive side.
I would really love to see Filezilla.
any luck getting sickrage as a rockon?
Iām new to Rockstor and just created my own Sickrage.json file using the Sickbeard.json as a template. Hereās the pull request for Sickrage; hopefully itāll be included in the next update.
This is great @Eric_Stewart! Iāll take a look and intend to merge it. Thank you!
I donāt have any specific Rock-ons application request but I would like to see and understand better how updates will be made visible in case there is one available?
Iām new to Rockstor (user since 1month->maybe there was none till now) - when pressing the āupdateā button would there be any notification or will the update be applied straight away without asking?
Maybe ridiculous, but the Rock-ons UI interface could be improved by making the list shorter (reduced space per entry) as there is anyhow very little text and an additional column could be added which shows the program version. e.g. 3 columns = 1 description, 1 version, 1 install/de-install
-> maybe a ātable viewā like under Services?
I would like to have a Unifi Controller Rock on. I recently purchased a UniFi AC Lite access point, and to get the most out of it I need to run the controller software on a server.
Can we get qbittorent, FileZilla, iTunes Server, Spotify, some open office server, a way to unzip and a File Manager?
Thank you.
I like to see:
PlexPy.
Subsonic (to stream to my sonos devices).
Why not just adding all LinuxServer.io docker images?
May i second that. Unify from Ubiquity.
The required Java is a mess on OSX and the controller fails to start.
Any news on an Amazon S3/Glacier cloud backup Rock-on?
I would like to be able to run virtual machine or docker container with a webgui.
Like php-virtualbox or cockpit for docker
I can look at adding not all, but most of Linuxserver.io as rock-ons.
It will take some time as I currently do no use rockstor as my NAS due to btrfs bugs.
Ill see what can be done in 2016.
Just getting started to RockStor but I am moving from my synology system to this and frequently use the following features. Some of them may already exist and I just havenāt discovered them yet.
I use mobile devices heavily and although I am comfortable at a linux command line, I donāt think its the best answer for day to day operations. So the following should have a consideration for thatā¦
- transmission (torrents) with RSS support
- File Manager (web based file manager, mobile ui friendly)
- syslog service (place to forward all of my syslogs)
- two factor sign on support
- Plex (of course)
- Virtual Servers (for setting up small websites)
- Automatic IP blacklisting for failed logins
- Amazon Drive Sync
