Hi @phillxnet, not demanding at all. I’m happy that someone is taking time to just look into it!
I ran the above commands, and also a fdisk -l just so you have an idea of the disks attached.
I can’t do the screenshots right now, but will send them to you tmrw once I’m back in the office.
And to retort… no rush, enjoy your xmas first!
Peter.
Ps. Just tried uploading a zip file with the output txt files, but forum only accepts images. So forgive the log paste below…
udevadm output:
P: /devices/virtual/block/md126 N: md126 L: 100 S: disk/by-id/md-uuid-2cc19c3c:3490fbf2:68b26e35:4bbd68cf S: md/System E: DEVLINKS=/dev/disk/by-id/md-uuid-2cc19c3c:3490fbf2:68b26e35:4bbd68cf /dev/md/System E: DEVNAME=/dev/md126 E: DEVPATH=/devices/virtual/block/md126 E: DEVTYPE=disk E: ID_PART_TABLE_TYPE=dos E: MAJOR=9 E: MD_CONTAINER=/dev/md/imsm0 E: MD_DEVICES=2 E: MD_DEVICE_sdm_DEV=/dev/sdm E: MD_DEVICE_sdm_ROLE=0 E: MD_DEVICE_sdn_DEV=/dev/sdn E: MD_DEVICE_sdn_ROLE=1 E: MD_DEVNAME=System E: MD_LEVEL=raid1 E: MD_MEMBER=0 E: MD_MON_THIS=../md127 E: MD_UUID=2cc19c3c:3490fbf2:68b26e35:4bbd68cf E: MINOR=126 E: SUBSYSTEM=block E: SYSTEMD_WANTS=mdmonitor.service mdmon@md127.service E: TAGS=:systemd: E: USEC_INITIALIZED=69792
lsblk output:
NAME="sda" MODEL="ST2000NM0023 " SERIAL="5000c50056565637" SIZE="1.8T" TRAN="sas" VENDOR="SEAGATE " HCTL="0:0:0:0" TYPE="disk" FSTYPE="btrfs" LABEL="RAID" UUID="b217cdf3-1390-487b-982b-136272978c51" NAME="sdb" MODEL="ST2000NM0023 " SERIAL="5000c5005663af0f" SIZE="1.8T" TRAN="sas" VENDOR="SEAGATE " HCTL="0:0:1:0" TYPE="disk" FSTYPE="btrfs" LABEL="RAID" UUID="b217cdf3-1390-487b-982b-136272978c51" NAME="sdc" MODEL="ST2000NM0023 " SERIAL="5000c500569db947" SIZE="1.8T" TRAN="sas" VENDOR="SEAGATE " HCTL="0:0:2:0" TYPE="disk" FSTYPE="" LABEL="" UUID="" NAME="sdd" MODEL="ST2000NM0023 " SERIAL="5000c500565cfaeb" SIZE="1.8T" TRAN="sas" VENDOR="SEAGATE " HCTL="0:0:3:0" TYPE="disk" FSTYPE="btrfs" LABEL="RAID" UUID="b217cdf3-1390-487b-982b-136272978c51" NAME="sde" MODEL="ST2000NM0023 " SERIAL="5000c5005663bca7" SIZE="1.8T" TRAN="sas" VENDOR="SEAGATE " HCTL="0:0:4:0" TYPE="disk" FSTYPE="btrfs" LABEL="RAID" UUID="b217cdf3-1390-487b-982b-136272978c51" NAME="sdf" MODEL="ST2000NM0023 " SERIAL="5000c50056639fa7" SIZE="1.8T" TRAN="sas" VENDOR="SEAGATE " HCTL="0:0:5:0" TYPE="disk" FSTYPE="btrfs" LABEL="RAID" UUID="b217cdf3-1390-487b-982b-136272978c51" NAME="sdg" MODEL="ST2000NM0023 " SERIAL="5000c5005663b263" SIZE="1.8T" TRAN="sas" VENDOR="SEAGATE " HCTL="0:0:6:0" TYPE="disk" FSTYPE="" LABEL="" UUID="" NAME="sdh" MODEL="ST2000NM0023 " SERIAL="5000c500569f1f5f" SIZE="1.8T" TRAN="sas" VENDOR="SEAGATE " HCTL="0:0:7:0" TYPE="disk" FSTYPE="" LABEL="" UUID="" NAME="sdi" MODEL="ST2000NM0023 " SERIAL="5000c5005663c1db" SIZE="1.8T" TRAN="sas" VENDOR="SEAGATE " HCTL="0:0:8:0" TYPE="disk" FSTYPE="btrfs" LABEL="RAID" UUID="b217cdf3-1390-487b-982b-136272978c51" NAME="sdj" MODEL="ST2000NM0023 " SERIAL="5000c50056639d37" SIZE="1.8T" TRAN="sas" VENDOR="SEAGATE " HCTL="0:0:9:0" TYPE="disk" FSTYPE="btrfs" LABEL="RAID" UUID="b217cdf3-1390-487b-982b-136272978c51" NAME="sdk" MODEL="ST2000NM0023 " SERIAL="5000c5005663b527" SIZE="1.8T" TRAN="sas" VENDOR="SEAGATE " HCTL="0:0:10:0" TYPE="disk" FSTYPE="btrfs" LABEL="RAID" UUID="b217cdf3-1390-487b-982b-136272978c51" NAME="sdl" MODEL="ST2000NM0023 " SERIAL="5000c5005663ac63" SIZE="1.8T" TRAN="sas" VENDOR="SEAGATE " HCTL="0:0:11:0" TYPE="disk" FSTYPE="btrfs" LABEL="RAID" UUID="b217cdf3-1390-487b-982b-136272978c51" NAME="sdm" MODEL="ST9250610NS " SERIAL="9XE0CT40" SIZE="232.9G" TRAN="sata" VENDOR="ATA " HCTL="2:0:0:0" TYPE="disk" FSTYPE="isw_raid_member" LABEL="" UUID="" NAME="md126" MODEL="" SERIAL="" SIZE="221.2G" TRAN="" VENDOR="" HCTL="" TYPE="raid1" FSTYPE="" LABEL="" UUID="" NAME="md126p1" MODEL="" SERIAL="" SIZE="500M" TRAN="" VENDOR="" HCTL="" TYPE="md" FSTYPE="ext4" LABEL="" UUID="17ec29b4-9284-4cb9-a0dc-10ae8c7cf720" NAME="md126p2" MODEL="" SERIAL="" SIZE="4G" TRAN="" VENDOR="" HCTL="" TYPE="md" FSTYPE="swap" LABEL="" UUID="6e15f5e8-5504-4950-9b94-a7da76ec6a95" NAME="md126p3" MODEL="" SERIAL="" SIZE="216.7G" TRAN="" VENDOR="" HCTL="" TYPE="md" FSTYPE="btrfs" LABEL="rockstor_system" UUID="4b445c9e-e130-42fa-87c5-6116db4dc662" NAME="sdn" MODEL="ST9250610NS " SERIAL="9XE0CTBG" SIZE="232.9G" TRAN="sata" VENDOR="ATA " HCTL="3:0:0:0" TYPE="disk" FSTYPE="isw_raid_member" LABEL="" UUID="" NAME="md126" MODEL="" SERIAL="" SIZE="221.2G" TRAN="" VENDOR="" HCTL="" TYPE="raid1" FSTYPE="" LABEL="" UUID="" NAME="md126p1" MODEL="" SERIAL="" SIZE="500M" TRAN="" VENDOR="" HCTL="" TYPE="md" FSTYPE="ext4" LABEL="" UUID="17ec29b4-9284-4cb9-a0dc-10ae8c7cf720" NAME="md126p2" MODEL="" SERIAL="" SIZE="4G" TRAN="" VENDOR="" HCTL="" TYPE="md" FSTYPE="swap" LABEL="" UUID="6e15f5e8-5504-4950-9b94-a7da76ec6a95" NAME="md126p3" MODEL="" SERIAL="" SIZE="216.7G" TRAN="" VENDOR="" HCTL="" TYPE="md" FSTYPE="btrfs" LABEL="rockstor_system" UUID="4b445c9e-e130-42fa-87c5-6116db4dc662"
fdisk output
Disk /dev/sdm: 250.1 GB, 250059350016 bytes, 488397168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk label type: dos
Disk identifier: 0x000bc92c
Device Boot Start End Blocks Id System
/dev/sdm1 * 2048 1026047 512000 83 Linux
/dev/sdm2 1026048 9414655 4194304 82 Linux swap / Solaris
/dev/sdm3 9414656 463888383 227236864 83 Linux
Disk /dev/sdn: 250.1 GB, 250059350016 bytes, 488397168 sectors
/dev/sdn1 * 2048 1026047 512000 83 Linux
/dev/sdn2 1026048 9414655 4194304 82 Linux swap / Solaris
/dev/sdn3 9414656 463888383 227236864 83 Linux
Disk /dev/sda: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
I/O size (minimum/optimal): 512 bytes / 4294966784 bytes
Disk /dev/sdf: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Disk /dev/sde: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Disk /dev/sdb: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Disk /dev/sdd: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Disk /dev/sdc: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Disk /dev/sdg: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Disk /dev/sdh: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Disk /dev/sdj: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Disk /dev/sdl: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Disk /dev/sdi: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Disk /dev/sdk: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Disk /dev/md126: 237.5 GB, 237510852608 bytes, 463888384 sectors
/dev/md126p1 * 2048 1026047 512000 83 Linux
/dev/md126p2 1026048 9414655 4194304 82 Linux swap / Solaris
/dev/md126p3 9414656 463888383 227236864 83 Linux`
