V5.0+ Testing Channel Changelog
5.0.11-0
Released in testing channel updates on 3rd July 2024
6th Stable Release Candidate (RC6)
Thanks to all who have helped us to get this far. Special thanks to forum members @coffax, @McFaul,
& @mpidala for their forum interactions to help pin-down the bugs that are now fixed in this release. As always thanks also to @Flox co-maintainer, and @Hooverdan forum moderator & all-around core contributor; both of which helped with the fixes here also.
What’s Changed
Test away and report rapidly as we work against the forces of kipple.
Released in testing channel updates on 11th July 2024
7th Stable Release Candidate (RC7)
Thanks to all who have helped us to get this far. Special thanks to @Flox co-maintainer, and @Hooverdan forum moderator & all-around core contributor.
Bar some recent forum reports - that have yet to be resolved fully to the GitHub issue stage, we have now cleared our next Stable Milestone: alas we have an outstanding Pi4 service fail on first reboot (noted on downloads page), but works if then started by-hand! And a curious Web-UI scrub status unknown issue - but the scrub is non-the-less executed OK! But as always: bit by bit.
What’s Changed
Released in testing channel updates on 17th July 2024
8th Stable Release Candidate (RC8)
As always: special thanks to @Flox co-maintainer, and @Hooverdan forum moderator & all-around core contributor.
  • @Tex1954 thanks for the “unknown” scrub reporting: should be fixed now. We had a hick-up in btrfs-progs version sensing: now improved to be more robust.
  • @Stevek thanks for reporting you findings re the Share resize: It related to an artifact of imported pool: but all good as we were due for some quota support improvements.
I would like to draw attention to the ‘13’ minor version designation here: please test extra thoroughly :slight_smile: .
What’s Changed
Released in testing channel updates on 27th August 2024
9th Stable Release Candidate (RC9)
  • @andyz Thanks for the detailed report re the system reserved home share issue, now fixed in this release.
  • @MyOwn Thanks for the Pi4 reboot confirmation. We finally tracked this down to extra systemd config required as a result of no persistent real-time-clock. That was a tricky one.
Counter to expectations, our prior 5.0.13-0 release was actually drama free: so we are definitely getting there :slight_smile: . Only minor / cosmetic / maintenance changes in this release, but we do have some long awaited multi container Rock-on fixes that we squeezed in to accommodate a specific Rock-on in-the-works. More on this when the time comes.
The remaining goals for the current testing channel phase are now minimal. Only show-stoppers will be entertained prior to some more cosmetics before we have our long awaited 5.1.x-x Stable tag.
A special testing request goes out to those familiar with our Share replication subsystem. Our “Routine update of dependencies” introduced a new major version of pyzmq. This is as-yet untested: but the prior version worked just dandy :slight_smile: .
What’s Changed
5.0.15-0
Released in testing channel updates on 19th November 2024
10th Stable Release Candidate (RC10)
  • @cellisten Thanks for a follow-up fix re leading spaces in lsblk values: hopefully we are now back where we were on this front, but with way more maintainable code post the major rework of that whole area that took place in the current testing phase.
  • @simon-77 Thanks for the detailed report re our NFS restoring as read-only. That lead, in turn, to a few improvements in our NFS code, including input validation improvements and a re-vamp of out test coverage which had fallen into disrepair.
  • @Stevek Thanks for your patient testing and reporting re a newer btrfs issue that seems to have thrown our replication. All in we have now, in this release resolved one of the issues found. But a quota one remains without a reliable replication: so I was unable to reproduce in order to prove a fix. I suspect it requires a non-trivial quota arrangement. But irrispective we now have one fixed so the remaining, if it still surfaces, should now be easier to narrow down. Leap 15.6 came with a way newer kernel so we have had to adapt to some of the newer btrfs behaviour there. Bit by bit.
This release has a lot of entries but many are cosmetic in nature, along with additional dependency pinning, ready for the next Stable release. We have also now addressed the confusing and contradictory tables re Rock-on pre & post config summary tables. That one has been hanging around for some time now. As always more improvements to be had but again, more eyes and fingers needed here.
And again: a special testing request goes out to those familiar with our Share replication subsystem. Re the issues generated from @Stevek testing reports.
What’s Changed
New Contributors
@cellisten made their first contribution in #2909
5.1.0-0
Released in testing channel updates on 30th May 2025
Not available for EOL Leap variants.
Final Stable Release Candidate
  • @simon-77 Thanks again for stepping in/up this time re an SMB TimeMachine config typo.
  • @kanecko We now implement a zypper retry on our more important zypper actions.
  • @chrstphrchvz This release addressed a couple of DNF-YUM Web-UI slowdowns that you raised quite some time ago now. Solution: we now make one machine readable zypper call to replace potentially hundreds of yum/rpm calls (human readable string parsed) from our now bygone era.
As this is, baring some barrier, our final stable release candidate, we have a few more Web-UI refinements now in place. But we have also now dropped all use of DNF/YUM from our olden-days. This is a big change, and was slated for later; but alas could wait no longer. After this update, the following should remove around 20 now unused packages (optional):
zypper remove --clean-deps dnf libdnf2 libdnf5_2
We have also moved forward significantly with plans to better support Tumbleweed-Slowroll: still not our primary OS target; but may become so in the future. Btrfs is progressive in nature, and rolling releases, or variants there-in, could server us well in this regard.
GPG key extension
Thanks to @Hooverdan for a timely heads-up on this one, and @Flox for key assistance :slight_smile: . Alas I had already fumbled the timing on this one - it’s been a busy year! But we are now set for future changes of this sort. Any necessity to import our expiration extended pkg & repo associated public GPG key can be met, as the root user, via:
rpm --erase gpg-pubkey-5f043187
rpm --import https://rockstor.com/ROCKSTOR-GPG-KEY
What’s Changed
