So i was trying to work out how much space i was realistically going to need for my backups (never got to do them before this happened), and so i ran du -hs * in /mnt2 this proceeded to basically crash the system, and upon finally coming back im getting error messages about the system being “out of space”
Run a df -h to see whats going on, because i knew i had around 50GB free space on the system drive/
Filesystem Size Used Avail Use% Mounted on
devtmpfs 7.5G 0 7.5G 0% /dev
tmpfs 7.5G 0 7.5G 0% /dev/shm
tmpfs 7.5G 761M 6.7G 10% /run
tmpfs 7.5G 0 7.5G 0% /sys/fs/cgroup
/dev/sde3 104G 53G 0 100% /
tmpfs 7.5G 0 7.5G 0% /tmp
/dev/sde3 104G 53G 0 100% /home
/dev/sde1 477M 199M 250M 45% /boot
tmpfs 1.5G 0 1.5G 0% /run/user/0
As hou can see the issue appears to be here
only 53GB used of 104GB but no more space available.
This has now left me with no webgui, non of my pools/shares mounted.
what i am seeing is systemd-journald using a lot of CPU, and if i run journalctrl -f i am getting this repeating at an unreadable rate
Sep 03 03:21:53 hulk kernel: ------------[ cut here ]------------
Sep 03 03:21:53 hulk kernel: WARNING: CPU: 0 PID: 2991 at fs/btrfs/qgroup.c:2955 btrfs_qgroup_free_meta+0xde/0xf0 [btrfs]
Sep 03 03:21:53 hulk kernel: Modules linked in: ebtable_filter ebtables ip6table_filter ip6_tables iptable_filter nct6775 hwmon_vid sunrpc dm_mirror dm_region_hash dm_log dm_mod dax ppdev eeepc_wmi asus_wmi sparse_keymap rfkill edac_mce_amd kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcbc ext4 jbd2 mbcache aesni_intel crypto_simd glue_helper cryptd pcspkr k10temp joydev input_leds shpchp sg sp5100_tco i2c_piix4 snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi parport_pc parport snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_seq snd_seq_device tpm_infineon snd_pcm snd_timer snd soundcore video wmi acpi_cpufreq ip_tables btrfs xor raid6_pq sd_mod crc32c_intel r8169 mii ahci libahci amdkfd libata amd_iommu_v2 radeon i2c_algo_bit drm_kms_helper syscopyarea sysfillrect
Sep 03 03:21:53 hulk kernel: sysimgblt fb_sys_fops ttm drm uas usb_storage
Sep 03 03:21:53 hulk kernel: CPU: 0 PID: 2991 Comm: in:imjournal Tainted: G W 4.12.4-1.el7.elrepo.x86_64 #1
Sep 03 03:21:53 hulk kernel: Hardware name: PC SPECIALIST System Product Name/A88XM-PLUS, BIOS 2903 03/10/2016
Sep 03 03:21:53 hulk kernel: task: ffff880409282d80 task.stack: ffffc90002fb0000
Sep 03 03:21:53 hulk kernel: RIP: 0010:btrfs_qgroup_free_meta+0xde/0xf0 [btrfs]
Sep 03 03:21:53 hulk kernel: RSP: 0018:ffffc90002fb3be0 EFLAGS: 00010206
Sep 03 03:21:53 hulk kernel: RAX: 0000000000000102 RBX: ffff880406120000 RCX: 0000000000000000
Sep 03 03:21:53 hulk kernel: RDX: 0000000000000000 RSI: 0000000000014000 RDI: ffff88040725e000
Sep 03 03:21:53 hulk kernel: RBP: ffffc90002fb3c08 R08: 0000000000000000 R09: 0000000000001400
Sep 03 03:21:53 hulk kernel: R10: 00000000ffffffe4 R11: 00000000000002a9 R12: ffff88040725e000
Sep 03 03:21:53 hulk kernel: R13: ffff880406120000 R14: 0000000000014000 R15: 0000000000014000
Sep 03 03:21:53 hulk kernel: FS: 00007f0885419700(0000) GS:ffff88041ec00000(0000) knlGS:0000000000000000
Sep 03 03:21:53 hulk kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Sep 03 03:21:53 hulk kernel: CR2: 00007f85a5314000 CR3: 00000003f5dd0000 CR4: 00000000000406f0
Sep 03 03:21:53 hulk kernel: Call Trace:
Sep 03 03:21:53 hulk kernel: start_transaction+0x378/0x440 [btrfs]
Sep 03 03:21:53 hulk kernel: btrfs_start_transaction+0x1e/0x20 [btrfs]
Sep 03 03:21:53 hulk kernel: btrfs_create+0x5a/0x220 [btrfs]
Sep 03 03:21:53 hulk kernel: path_openat+0xf1f/0x13b0
Sep 03 03:21:53 hulk kernel: ? unix_dgram_sendmsg+0x2b1/0x690
Sep 03 03:21:53 hulk kernel: do_filp_open+0x91/0x100
Sep 03 03:21:53 hulk kernel: ? __alloc_fd+0x46/0x170
Sep 03 03:21:53 hulk kernel: do_sys_open+0x124/0x210
Sep 03 03:21:53 hulk kernel: SyS_open+0x1e/0x20
Sep 03 03:21:53 hulk kernel: entry_SYSCALL_64_fastpath+0x1a/0xa5
Sep 03 03:21:53 hulk kernel: RIP: 0033:0x7f0888cb277d
Sep 03 03:21:53 hulk kernel: RSP: 002b:00007f0885417c30 EFLAGS: 00000293 ORIG_RAX: 0000000000000002
Sep 03 03:21:53 hulk kernel: RAX: ffffffffffffffda RBX: 00007f0878000020 RCX: 00007f0888cb277d
Sep 03 03:21:53 hulk kernel: RDX: 00000000000001b6 RSI: 0000000000000241 RDI: 00007f0885417cd0
Sep 03 03:21:53 hulk kernel: RBP: 00007f0878000020 R08: 00007f0886d8ed8c R09: 0000000000000240
Sep 03 03:21:53 hulk kernel: R10: 0000000000000024 R11: 0000000000000293 R12: 00007f0885418db0
Sep 03 03:21:53 hulk kernel: R13: 00007f0875aa174b R14: 0000000000000020 R15: 000000000000000a
Sep 03 03:21:53 hulk kernel: Code: 48 8b 03 4d 89 f7 49 f7 df 48 8b 7b 08 48 83 c3 18 4c 89 fa 4c 89 e6 ff d0 48 8b 03 48 85 c0 75 e8 49 8b 84 24 38 03 00 00 eb 98 <0f> ff eb 86 0f 0b 66 90 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44
Sep 03 03:21:53 hulk kernel: ---[ end trace 905ef2e4814bc84a ]---
Any help will be greatly appreciated.
Thanks in advance
Matt
