Usage data on pools and shares not updated
I’ve had this issue ever since I’ve been running Rockstor as well (at least 6 month’s, possibly longer). Am running stable at the moment. Currently got 12 drives, each 4TB, setup in raid6.
Rockstor version: 3.8-13
Linux: 4.4.5-1.el7.elrepo.x86_64
btrfs fi show output:
Label: ‘rockstor_rockstor’ uuid: 316c1ade-0b12-4dfd-8768-361792c73894
Total devices 1 FS bytes used 2.31GiB
devid 1 size 224.52GiB used 33.02GiB path /dev/sde3
Label: ‘storage’ uuid: 3944e3a0-3cd7-445e-83da-f78aa096df59
Total devices 12 FS bytes used 18.49TiB
devid 1 size 3.64TiB used 1.86TiB path /dev/sdc
devid 2 size 3.64TiB used 1.86TiB path /dev/sdd
devid 3 size 3.64TiB used 1.86TiB path /dev/sdf
devid 4 size 3.64TiB used 1.86TiB path /dev/sdg
devid 5 size 3.64TiB used 1.86TiB path /dev/sdh
devid 6 size 3.64TiB used 1.86TiB path /dev/sdi
devid 7 size 3.64TiB used 1.86TiB path /dev/sda
devid 8 size 3.64TiB used 1.86TiB path /dev/sdb
devid 9 size 3.64TiB used 1.86TiB path /dev/sdl
devid 10 size 3.64TiB used 1.86TiB path /dev/sdm
devid 11 size 3.64TiB used 1.86TiB path /dev/sdk
devid 12 size 3.64TiB used 1.86TiB path /dev/sdj
df -h on a server that has the storage share mounted;
Filesystem Size Used Avail Use% Mounted on
192.168.1.201:/export/storageshare 44T 19T 22T 47% /storage
Screenshot of disks page, pools page, shares page and total capacity widget: http://imgur.com/a/jkeC7
Most of the time mine’s completely inaccurate, I’d put it down to either Raid5/6 or Snapshots.
I’m running RAID 1 and I have the same issue. Rockstor Dashboard shows zero usage on a share that has over 1TB of data in it. I don’t know what the problem is. It makes it difficult for me to tell when to add new drives to the array, I have to really keep track. I’m running the most current build, not using stable updates yet.
Some of the problems in this thread are unfortunately inherent to the use of btrfs. For example, output from the system commands df and du will generally be different from that of btrfsprogs btrfs filesystem df/du. The reason is that filesystem metadata, RAID levels and subvolumes all make the concept of “free space” much more complicated, also depending on whether you look at a whole filesystem or an individual share. The developers themselves explain this better in their FAQ section.
There is another issue with “zero usage” showing after making changes to a btrfs pool; this particular one can be resolved by performing btrfs quota rescan /path/to/pool.
At the moment, the usage reported for pools should be the most accurate. I’ve started an attempt to get a bit more sense into the share usage as well, with some changes to the shares list view in the most recent (3.8-14.10) version. Notably though, I haven’t touched the dashboard view yet. I’m keeping a list of current problems in this github issue:
Feel free to comment or contribute there as well.
Good enough! As long as there is somewhere I can find information about my space remaining, I’ll be able to get by. Share data doesn’t matter that much because there is no share size enforcement anyhow, so all I need to know is when to add more drives.
Is there any way to get the correctly reported size from the Pool page to show in the dashboard? That would be super helpful, even if it is only a temporary solution.
That’s a good idea and shouldn’t be too hard, I’ll look into it.
Actually it should be possible to implement a finer grained size enforcement by making each share a subvolume and using btrfs’s quota groups, but that would require some more work.
Fantastic! Thanks. Please check in if that change works its way into a future patch.
I’ve submitted a pull request with the new dashboard widget:
If you want to test the changes even before they get accepted, you can download the two files to the proper location on your system, followed by:
# cd /opt/rockstor
# bin/buildout install collectstatic
That’s awesome! Thanks so much. This is a simple, but very helpful change until BTRFS is 100% functional on the reporting side of things.
Hi @sfranzen,
had a quick test on your pool widget and it seems ok, but here is my question:
What do you think about merging pool & share widgets together??? IMHO it could be better
Flyer/Mirko
Thanks for the zero usage fix.
This has made my dashboard show real / realistic values again :slight_smile:
Hey Mirko,
Well, I think several parts of the dashboard could do with some touch-ups; I just copy/pasted this thing together quickly to provide at least something. I’m currently looking at a suggestion from another user to do the dashboard in Patternfly. If that’s going to work, all widgets will have to be rewritten anyway.
Hi @sfranzen, can I assume you won’t move to Patternfly in the short time??
I think it can be quite easy (Patternfly made over Bootstrap, already running on Rockstor), but meanwhile I’m working on Dashboard widgets and this
Current dashboard crashes are because of D3.js library (not the library itself, but our use of it with 1 sec dynamic data updates on graphs) so I’m having some tests to move from d3.js SVG to chart.js canvas ( Nice post about SVG vs canvas & performance )
To check it, try this : https://jsfiddle.net/u5aanta8/29/ ( a little jsfiddle I’ve done to emulate Rockstor graphs, you can leave it open a long time without performance issues :slight_smile: )
Flyer
@sfranzen Just chipping in here:
There is also an outstanding dashboard patch / enhancement by way of this pr:
Not sure if it’s really relevant if re-writes were planned but popping in here just in case.
I submitted it to partially repair some aesthetics I broke on a previous pr, some discussion in there also.
The approach there is a little fragile still, especially with long serial numbers, so might be best if that whole widget was re-thought anyway, ie only shows top 3 or 5 after patch depending on current widget size anyway.
@Flyer Name dropping you as I know you are already aware of this pr and as you indicate working in this area.
I know that the dashboard ‘as is’ takes a larger amount of client CPU than I would have thought necessary but I’m pretty green on js / web programming so might be a red herring.
@Flyer Yeah I won’t be in a hurry :wink:. I personally haven’t had this issue, but I did see there is a lot of hand-crafted SVG stuff in there. Glad there is a better method.
@phillxnet Well so am I :stuck_out_tongue:. My experience is mostly in C++/Qt as far as UIs go, but I thought I’d use rockstor as a tool to learn more about this.
@suman
even with the latest 3.9.0 release it seems that the data usage issue is still not solved (?)
Almost all of belows indicated data usage is wrong (to less of MB/GB)
The only one that looks ok, seems this dashboard
Thanks for any comments
Hi Roland,
looking your screenshots there’s something I don’t understand :confused: :
rm_share has 4.30GB data + 4.36 GB for btrfs “overhead” so you should have a different top shares chart (overhead = light blue and current “real data” 4.30 GB dark blu)
Uhmm…did you update to latest Rockstor right now?? We had usage/btrfs usage on a previous code update and it seems ok
@suman & @phillxnet ?
Mirko
P.S.: waiting for 3.9.0 announcement :smiley:
@Flyer I’m using already 3.9.0 which has been released over night, automatically installed.
Yes, very strange screens on my machine
@phillxnet
Hi, any advice from a disk and file system expert? :wink:
See aboves threads…THX
@glenngould
Hardly: as it goes @Flyer is our ‘size reporting person’ (among many other talents), and has done a fair bit to get us closer to accurate reporting; including a rewrite of the dashboard since I was last on this thread. Best to look into btrfs commands to report disk and subvolume usages and paste the output here to give others more info to work with.
For example you could paste the output of:
btrfs fi usage /mnt2/zm_data
and
btrfs qgroup show /mnt2/zm_data
or any other subvolume name that is displaying much less usage than you expect.
That way we can have a look at where Rockstor’s use of equivalent commands is being ‘miss-reported’ in the user interface.
Thanks, sorry I can’t spend more time on this right now but as I know is the case with @Flyer as well, we are involved in other, also pressing issues. Please be patient as it is our intention to address this but their is obviously something a little strange with your figures that are not mirrored with our own installs. Can you tell us anything more about your current setup and it’s history, did you for example import this pool from a previous install, things like that might help to narrow down why your size reports are mis-reporting.
Hope that helps and if you could paste the output of those commands then maybe someone can see where Rockstor’s use of similar commands is going astray.
Cheers.
